Survey123 Splitting Repeats into separate layer
395
07-11-2018 07:28 AM
BobbiPritt
When trying to make a survey with a repeating section, the resulting repeat is split into a separate table when the survey is imported as a layer. Is ther a way to prevent this from happening or recombine the tables in map viewer? The survey involves take several pictures and gps coordinates at a single area.
by Anonymous User
Not applicable
Hi Bobbi,
I see you have started by creating your survey in Web Designer on the website, and then moved to Connect. In this case you should be aware of what changes you can make that will not effect the feature service.
A repeat is a related table/layer to the parent feature layer, and it will always be added this way via Connect when using a begin_repeat question. This is a one to many relationship to allow you to add many records (inspections for example) against the parent feature.
More information on repeats in Survey123 can be found here: Repeats—Survey123 for ArcGIS | ArcGIS
Phil.
