Model Failing on Translate LRM to LRM
721
07-06-2018 10:08 AM
anayoung
New Contributor III
I've been trying to edit a model (which I inherited) that keeps failing on the Translate Events from LRM to LRM. The message says that the XY tolerance is different between the source and target files. The problem appears to me that the source file is a shapefile and the target file is a feature class; the source shapefile is created by the Identity tool which uses a temporary folder on the C:\drive to store the shapefile and then goes through a series of geoprocessing steps before being entered into the LRM to LRM tool with the feature class.
I tried changing the output location of the source file to be the same geodatabase as the target file in the Identity tool step but then the tool fails to create an output in the geodatabase.
The weird thing is that there's another very similar model which works fine but I cannot find what the difference between them is other than the inputs and outputs. I'm a novice model maker so it's quite possible that I'm missing some fundamentals of model building here.
I have attached a copy of both models for your review; the one that fails is called " Recreate GP_MetroPlanningArea" and the one that works is called "Recreate GP Municipality". Also, attached, are screen shots of the error messages I have described above. The database I use for the original two files (i.e. "BM Metro Planning Areas" and "StatewideRoutes") is way to large to attach here.
Ana
curtvprice
MVP Esteemed Contributor
Interestingly the example in the help has the input and the output in the same geodatabase. The example also has the same database set as the default workspace in the environment.
I think the issue is you the output workspace you are defining doesn't include the '.gdb' at the end of the path. Without that it will try to write the output a folder (not .gdb) which will not work. Hard to tell as your error messages are cut off so I can't see the complete paths. (By the way, you can copy and paste the complete error messages as text by opening the Geoprocessing > Results window, right click Messages, View.)
curtvprice
anayoung
New Contributor III
Thank you, Curtis. I am looking into it.
anayoung
New Contributor III
Hi Curtis,
It looks like the model is naming two different outputs: "Recreate_GP_MetroPlanningArea_20180706.gdb" and "%Staging.gdb%". I've been assuming that the %Staging.gdb% was just a reference to Recreate_GP_MetroPlanningArea_20180706.gdb
I don't get why the model creates the source event layer as a shapefile and the target is created as a feature class. I have highlighted in bold the creation of those files and the failure message below:
Executing: RecreateGPMetroPlanningArea U:\GPModels\MetropolitanPlanningAreas U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes "ToDate IS NULL AND "RouteID" = '999_LA 1_1_1_010'" 2017
Start Time: Fri Jul 06 11:31:41 2018
Executing (Calculate Value (Date)): CalculateValue time.strftime("%Y%m%d") # Variant
Value = 20180706
Succeeded at Fri Jul 06 11:31:42 2018 (Elapsed Time: 0.12 seconds)
Executing (Create File GDB): CreateFileGDB U:\GPModels\MetropolitanPlanningAreas Recreate_GP_MetroPlanningArea_20180706 CURRENT
Start Time: Fri Jul 06 11:31:42 2018
Succeeded at Fri Jul 06 11:31:44 2018 (Elapsed Time: 2.30 seconds)
Executing (Feature Class to Feature Class (2)): FeatureClassToFeatureClass U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb fc_StatewideRoutes "ToDate IS NULL AND "RouteID" = '999_LA 1_1_1_010'" "FromDate "FromDate" true true false 8 Date 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,FromDate,-1,-1;ToDate "ToDate" true true false 8 Date 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,ToDate,-1,-1;RouteID "RouteID" true true false 255 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,RouteID,-1,-1;SystemCode "SystemCode" true true false 4 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,SystemCode,-1,-1;RouteNameFull "RouteNameFull" true true false 100 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,RouteNameFull,-1,-1;InventoryDirection "InventoryDirection" true true false 3 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,InventoryDirection,-1,-1;FeatureTypeCode "FeatureTypeCode" true true false 2 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,FeatureTypeCode,-1,-1;SequenceNumber "SequenceNumber" true true false 3 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,SequenceNumber,-1,-1;DescriptionFrom "DescriptionFrom" true true false 255 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,DescriptionFrom,-1,-1;DescriptionTo "DescriptionTo" true true false 255 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,DescriptionTo,-1,-1;DominanceOrder "DominanceOrder" true true false 3 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,DominanceOrder,-1,-1;RouteNumber "RouteNumber" true true false 6 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,RouteNumber,-1,-1;created_user "created_user" false true false 255 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,created_user,-1,-1;created_date "created_date" false true false 8 Date 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,created_date,-1,-1;last_edited_user "last_edited_user" false true false 255 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,last_edited_user,-1,-1;last_edited_date "last_edited_date" false true false 8 Date 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,last_edited_date,-1,-1;SHAPE_Length "SHAPE_Length" false true true 8 Double 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\StatewideRoutes,SHAPE_Length,-1,-1" #
Start Time: Fri Jul 06 11:31:44 2018
Succeeded at Fri Jul 06 11:31:54 2018 (Elapsed Time: 10.25 seconds)
Executing (Delete Field (2)): DeleteField U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes SystemCode;RouteNameFull;InventoryDirection;FeatureTypeCode;SequenceNumber;DescriptionFrom;DescriptionTo;DominanceOrder;RouteNumber;created_user;created_date;last_edited_user;last_edited_date
Start Time: Fri Jul 06 11:31:54 2018
Dropping SystemCode from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping RouteNameFull from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping InventoryDirection from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping FeatureTypeCode from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping SequenceNumber from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping DescriptionFrom from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping DescriptionTo from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping DominanceOrder from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping RouteNumber from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping created_user from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping created_date from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping last_edited_user from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Dropping last_edited_date from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes...
Succeeded at Fri Jul 06 11:32:00 2018 (Elapsed Time: 5.38 seconds)
Executing (Feature Class to Feature Class): FeatureClassToFeatureClass U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb fc_BM_City_Limits # "UUID "UUID" true true false 20 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,UUID,-1,-1;MPO_Name "MPO_Name" true true false 50 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,MPO_Name,-1,-1;Metro_Area_Code "Metro_Area_Code" true true false 5 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,Metro_Area_Code,-1,-1;Date_Adopted "Date_Adopted" true true false 8 Date 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,Date_Adopted,-1,-1;Square_Miles "Square_Miles" true true false 8 Double 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,Square_Miles,-1,-1;created_user "created_user" false true false 255 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,created_user,-1,-1;created_date "created_date" false true false 8 Date 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,created_date,-1,-1;last_edited_user "last_edited_user" false true false 255 Text 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,last_edited_user,-1,-1;last_edited_date "last_edited_date" false true false 8 Date 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,last_edited_date,-1,-1;SHAPE_Length "SHAPE_Length" false true true 8 Double 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,SHAPE_Length,-1,-1;SHAPE_Area "SHAPE_Area" false true true 8 Double 0 0 ,First,#,U:\GPModels\MetropolitanPlanningAreas\RHWORK_20180615_1_1_1.gdb\BaseMap\BM_Metropolitan_Planning_Areas,SHAPE_Area,-1,-1" #
Start Time: Fri Jul 06 11:32:00 2018
Succeeded at Fri Jul 06 11:32:03 2018 (Elapsed Time: 3.17 seconds)
Executing (Delete Field): DeleteField U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits UUID;MPO_Name;Date_Adopted;Square_Miles;created_user;created_date;last_edited_user;last_edited_date
Start Time: Fri Jul 06 11:32:03 2018
Dropping UUID from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits...
Dropping MPO_Name from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits...
Dropping Date_Adopted from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits...
Dropping Square_Miles from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits...
Dropping created_user from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits...
Dropping created_date from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits...
Dropping last_edited_user from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits...
Dropping last_edited_date from U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits...
Succeeded at Fri Jul 06 11:32:06 2018 (Elapsed Time: 2.96 seconds)
Executing (Identity): Identity U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_BM_City_Limits C:\Temp\arcDEA9\fc_StatewideRoutes_Identity.shp ALL # NO_RELATIONSHIPS
Start Time: Fri Jul 06 11:32:07 2018
Reading Features...
Cracking Features...
Assembling Features...
Succeeded at Fri Jul 06 11:32:07 2018 (Elapsed Time: 0.82 seconds)
Executing (Dissolve): Dissolve C:\Temp\arcDEA9\fc_StatewideRoutes_Identity.shp C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_.shp RouteID;Metro_Area # MULTI_PART DISSOLVE_LINES
Start Time: Fri Jul 06 11:32:08 2018
Sorting Attributes...
Dissolving...
Succeeded at Fri Jul 06 11:32:09 2018 (Elapsed Time: 0.45 seconds)
Executing (Multipart To Singlepart (2)): MultipartToSinglepart C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_.shp C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_1.shp
Start Time: Fri Jul 06 11:32:09 2018
Succeeded at Fri Jul 06 11:32:09 2018 (Elapsed Time: 0.23 seconds)
Executing (Add Field 'From Measure'): AddField C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_1.shp FromMeasur DOUBLE # # # # NULLABLE NON_REQUIRED #
Adding FromMeasur to C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_1.shp...
Succeeded at Fri Jul 06 11:32:09 2018 (Elapsed Time: 0.03 seconds)
Executing (Calculate Field 'From Measure'): CalculateField C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_1.shp FromMeasur 0 VB #
Succeeded at Fri Jul 06 11:32:09 2018 (Elapsed Time: 0.17 seconds)
Executing (Add Field 'To Measure'): AddField C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_1.shp ToMeasure DOUBLE # # # # NULLABLE NON_REQUIRED #
Adding ToMeasure to C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_1.shp...
Executing (Calculate Field 'To Measure'): CalculateField C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_1.shp ToMeasure 1 VB #
Executing (Translate Events From LRM To LRM): TranslateEventsFromLRMToLRM C:\Temp\arcDEA9\fc_StatewideRoutes_Identity_1.shp "RouteID LINE FromMeasur ToMeasure" U:\GPModels\MetropolitanPlanningAreas\Recreate_GP_MetroPlanningArea_20180706.gdb\fc_StatewideRoutes RouteID ROUTE_ID %Staging.gdb%/MetroPlanningAreas_ReadyToLoad
Source Event Layer: fc_StatewideRoutes_Identity_1
Target LRM Network Layer: fc_StatewideRoutes
XY Tolerance is different in Source Event and Target LRM Network feature classes.
Output Feature Class: MetroPlanningAreas_ReadyToLoad
Output Workspace: null
Unable to parse parameters.
Failed to execute (Translate Events From LRM To LRM).
Failed at Fri Jul 06 11:32:10 2018 (Elapsed Time: 0.08 seconds)
Failed to execute (RecreateGPMetroPlanningArea).
Failed at Fri Jul 06 11:32:10 2018 (Elapsed Time: 28.59 seconds)
