AnsweredAssumed Answered
How to put two shapefile layers together
Question asked by kkkevis on Jul 5, 2018
Latest reply on Jul 9, 2018 by jborgion
Hello guys. I have two shapefiles, here are the properties they show in the Arcmap layers:
A) is the land use/cover change shapefile:
Extent:
Top:3706773.068100m
Left:-336160.544000m
Right: 416248.789700m
Bottom:3215361.941100m
Data source:
Data Type: Personal Geodatabase Feature Class
Database: G:\Land use change\New Personal Geodatabase.mdb
Feature Class: ld_2015_prj
Feature Type: Simple
Geometry Type: Polygon
Coordinates have Z values: No
Coordinates have measures: No
Projected Coordinate System: WGS_1984_UTM_Zone_50N
Projection: Transverse_Mercator
False_Easting: 500000.00000000
False_Northing: 0.00000000
Central_Meridian: 117.00000000
Scale_Factor: 0.99960000
Latitude_Of_Origin: 0.00000000
Linear Unit: Meter
Geographic Coordinate System: GCS_WGS_1984
Datum: D_WGS_1984
Prime Meridian: Greenwich
Angular Unit: Degree
B)is the boundry of the country (much larger than the area of A), also a shapefile:
Extent:
Top:62.585600m
Left:-845172.275.544000m
Right: -845117.1756.789700m
Bottom:7.383400m
Data source:
Feature Class: boundry_prj
Linear Unit: Meter
Datum: D_WGS_1984
My problem is, when I put them into one map, B) just diappeared. And B) even doesn't showed in a blank map. I know the problems come from the extent as it looks so odd. I don't know whether it's the problem of data or shapefile document, or somewhere wrong.  I remember that once they showed together, but I don't see it anymore and I totally forget how I did it.
BTW, my question is very similar to Robert(2012):
see  Defining / Changing spatial extent of shapefile
But it seems that the anwer does't help me a lot.
Thanks guys.
Qing
Outcomes
