Customized Quickreport 10.2.7 app fails when trying to build
582
07-05-2018 02:20 AM
KamranYusaf1
New Contributor III
I have an app based on the quickreport template 10.2.7, which has been customized(some functionality added, and some functionality removed). When i try to build the app using Appstudio for Desktop(cloud make) i get the following error:
I have tried to build it locally aswell and get the same error:
c:/users/kamrany/downloads/android-ndk-r10e-windows-x86_64/android-ndk-r10e/toolchains/arm-linux-androideabi-4.9/prebuilt/windows-x86_64/bin/../lib/gcc/arm-linux-androideabi/4.9/../../../../arm-linux-androideabi/bin/ld.exe: internal error in do_fill_plt_entry, at /s/ndk-toolchain/src/build/../binutils/binutils-2.25/gold/arm.cc:7805
collect2.exe: error: ld returned 1 exit status
Makefile:78: recipe for target '..\..\Output\android\libAppStudioApp.so' failed
mingw32-make: *** [..\..\Output\android\libAppStudioApp.so] Error 1
Build Failed.
I have attached the logfile from the local make.
Does anyone know what causes the error? And how to solve this?
Any help would be appreciated.
ShobanaSuresh
Hi Kamran Yusaf‌,
I believe you are using AppStudio 2.1 since your app uses the 10.2.6 ArcGIS Runtime. I checked the build logs on our Cloud Make build servers and can see that the build request for your app has failed with the same error you get with Local Make.
qml: /ld: internal error in do_fill_plt_entry, at /s/ndk-toolchain/src/build/../binutils/binutils-2.25/gold/arm.cc:7805
Please note that AppStudio 2.1 uses Qt5.9.1 for building apps in the Cloud Make build environment. We do not support building apps with Qt5.11.1 + Local Make + AppStudio 2.1. Qt5.9.1 has to be used with AppStudio 2.1 + Local Make
However, the build error does not appear to be related to the Qt version used. The build fails when linking due to an increase in the App binary size. Were any new files added to the app recently?  Can you try removing unused images / reduce image size and try building again?
Shobana
ErwinSoekianto
Hello Kamran Yusaf‌ ,
This is weird.
Did this error occur before or start to happen after you make certain changes to the code?
And can the same app be run on AppRun and/or AppStudio Player?
The build log points that you are using Local Make and it points to Qt 5.11.1 in which we are not using yet. Currently, the AppStudio Desktop 3.0.x is using Qt 5.10.
Which version of AppStudio Dekstop are you using?
But it still puzzles me why this is failing on Clould Make.
Thank you,
Erwin
ShobanaSuresh
Hi Kamran Yusaf‌,
Shobana
KamranYusaf1
New Contributor III
Hi Shobana,
It is workning after i deleted unnecessary files from the app.
