AnsweredAssumed Answered
WebGISDR failing for Full recovery
Question asked by Szymon.Piskula_WoodMacOnline on Jul 5, 2018
Latest reply on Sep 24, 2019 by JQuinn-esristaff
I have a fairly complex 10.6 setup on multiple windows 2016 with all elements being HA/duplicated:
-Portal
-Hosting AGS Site
--Separate Relational DS cluster
--Separate TileCache DS cluster
-Federated AGS Site
Everything works fine on it, stuff gets published, users can deal with it, hosted layers get created, map services work, all good.
Yesterday i have successfully created a full webgisdr backup (including tilecaches). No errors upon creation of the backup all looks good. Today i was going to test if webgisdr tool works/verify my DR procedure. Sadly upon calling the webgisdr tool with --import option the recovery fails with message:
Failed to validate the ArcGIS Data Store for the web GIS. The ArcGIS Data Store in the web GIS backup does not match the ArcGIS Data Store in the current web GIS.
Nothing has changed in terms of machines in any of the sites/nodes. All machine names are the same, Load Balancer URLs are the same. Yet it feels like the message indicates a mismatch?
Here is the console output when i run the tool:
Starting the WebGIS DR utility.
The configuration and base backup time in the current Web GIS
Portal: https://portal.<site>/portal
|-- Federated Server: https://mapping.<site>/server
|-- Hosting Server: https://hosted.<site>/server
| |-- Relational Data Store: https://ec2amaz-<relational-id>.mydomain.local:2443/arcgis
| |-- TileCache Data Store: https://ec2amaz-<tilecache-id>.mydomain.local:2443/arcgis
Unzipping the backup file:
\\<backups>\July-4-2018-11-29-39-AM-EDT-FULL.webgissite
The backup file has been unzipped in 00hr:12min:15sec.
The backup file was created at July 4, 2018 11:29:39 AM EDT.
The configuration and base backup time in the incoming Web GIS
Portal: https://portal.<site>/portal at 7/4/18 11:24 AM
|-- Federated Server: https://mapping.<site>/server at 7/4/18 11:24 AM
|-- Hosting Server: https://hosted.<site>/server at 7/4/18 11:24 AM
Starting the restore process with the WebGIS DR utility.
Exiting the WebGIS DR utility.
Here is the 'crucial' section of the additional log file in DEBUG mode:
2018-07-05 08:36:55 DEBUG [main] org.apache.http.impl.execchain.MainClientExec - Connection can be kept alive indefinitely
2018-07-05 08:36:55 DEBUG [main] org.apache.http.impl.conn.PoolingHttpClientConnectionManager - Connection [id: 144][route: {s}->https://hosted.<site>:443] can be kept alive indefinitely
2018-07-05 08:36:55 DEBUG [main] org.apache.http.impl.conn.PoolingHttpClientConnectionManager - Connection released: [id: 144][route: {s}->https://hosted.<site>:443][total kept alive: 1; route allocated: 1 of 2; total allocated: 1 of 20]
2018-07-05 08:36:55 DEBUG [main] org.apache.http.impl.conn.PoolingHttpClientConnectionManager - Connection manager is shutting down
2018-07-05 08:36:55 DEBUG [main] org.apache.http.impl.conn.DefaultManagedHttpClientConnection - http-outgoing-144: Close connection
2018-07-05 08:36:55 DEBUG [main] org.apache.http.impl.conn.PoolingHttpClientConnectionManager - Connection manager shut down
2018-07-05 08:36:55 DEBUG [main] com.esri.arcgis.webgis.util.WebGISUtil - {"incrementalBackupTimeStamp":1530770427265,"backupMode":"FULL","incrementalRestoreTimeStamp":0,"fullBackupTimeStamp":1530789177251,"fullRestoreTimeStamp":0}
2018-07-05 08:36:55 INFO [main] com.esri.arcgis.webgis.storageservice.file.FileStorageService - Unzipping the backup file:
2018-07-05 08:49:10 INFO [main] com.esri.arcgis.webgis.util.WebGISUtil - The backup file has been unzipped in 00hr:12min:15sec.
2018-07-05 08:49:10 INFO [main] com.esri.arcgis.webgis.service.impl.WebGISDRFrontController - The backup file was created at July 4, 2018 11:29:39 AM EDT.
2018-07-05 08:49:10 DEBUG [main] com.esri.arcgis.webgis.service.impl.WebGISDRFrontController - Failed to validate the current Web GIS.
com.esri.arcgis.webgis.WebGISException: Failed to validate the ArcGIS Data Store for the web GIS. The ArcGIS Data Store in the web GIS backup does not match the ArcGIS Data Store in the current web GIS.
at com.esri.arcgis.webgis.service.impl.WebGISDRFrontController.a(WebGISDRFrontController.java:818)
at com.esri.arcgis.webgis.service.impl.WebGISDRFrontController.a(WebGISDRFrontController.java:221)
at com.esri.arcgis.webgis.service.impl.WebGISDRFrontController.service(WebGISDRFrontController.java:103)
at com.esri.arcgis.webgis.service.impl.WebGISDRManager.c(WebGISDRManager.java:142)
at com.esri.arcgis.webgis.service.impl.WebGISDRManager.importWebGIS(WebGISDRManager.java:125)
at com.esri.arcgis.webgis.client.WebGISDR.main(WebGISDR.java:103)
2018-07-05 08:49:10 DEBUG [main] com.esri.arcgis.webgis.service.impl.WebGISDRFrontController - Deleting the temp directory \\<share>\tempbackups\WebGISSite1530794203646.
2018-07-05 08:49:12 DEBUG [main] com.esri.arcgis.webgis.client.WebGISDR - Exiting the WebGIS DR utility.
at com.esri.arcgis.webgis.service.impl.WebGISDRFrontController.a(WebGISDRFrontController.java:224)
Caused by: com.esri.arcgis.webgis.WebGISException: Failed to validate the ArcGIS Data Store for the web GIS. The ArcGIS Data Store in the web GIS backup does not match the ArcGIS Data Store in the current web GIS.
... 4 common frames omitted
2018-07-05 08:49:12 ERROR [main] com.esri.arcgis.webgis.client.WebGISDR - Failed to validate the ArcGIS Data Store for the web GIS. The ArcGIS Data Store in the web GIS backup does not match the ArcGIS Data Store in the current web GIS.
Regards,
Szymon
Outcomes
