ArcGIS 10.6 Toolbox crash
1020
5
07-04-2018 03:00 AM
YvesDe_Graeve
I'm having a hard time getting ArcGIS 10.6 to work properly on a win10 Panasonic tablet.
Already did a complete reinstall but to no avail.
Right click with a stylus pen does not work, however when I switch to a Windows folder it does.
Toolbox -> export to cad crashes when I try to add features.
Respons is unbelievable slow.. it takes on average 10 minutes to open a file.
Any ideas on what to do to jumpstart 10.6 ?
Thanks Yves
DanPatterson_Retired
How did it fair on the ability to run 10.6?
run the link on this page
http://desktop.arcgis.com/en/arcmap/latest/get-started/setup/arcgis-desktop-system-requirements.htm
YvesDe_Graeve
We have 4 other Panasonic tablets running 10.1 just fine without any issues.
I checked the hardware requirements before installing 10.6 on our 4 new tablets, so it's within specs.
As long as you ran the link there... it reveals more than the specs (repo'ed here)
Supported platforms
Check your computer's ability to run ArcMap
YvesDe_Graeve
Dan, I ran the test and these are the results.
Minimum:
CPU
Minimum: Intel Core Duo, SSE2 (or greater) Pentium 4 or Xeon Processors
You Have: Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz
CPU SPEED
CPU SPEED
Minimum: 2.2 GHz minimum or higher
You Have: 2.5 GHz Performance Rated at: 6 GHz
VIDEO CARD
VIDEO CARD
Minimum: 24-bit capable graphics accelerator with 64 MB of video memory, OpenGL version 2.0 runtime
You Have: Intel(R) HD Graphics 520
Features: Minimum attributes of your Video Card
RequiredYou Have
IconTotal Video RAM64 MB6.0 GB
IconPixel Shader2.05.0
IconVertex Shader2.05.0
RAM
RAM
Minimum: 4 GB
You Have: 8.0 GB
OS
OS
Minimum: Windows 7 Ultimate, Pro, and Ent SP1, Windows 8.1 Basic, Pro, and Ent Sept. 2016 Updt, Windows 10 (64 bit [EM64T]) Creators Updt, Windows SVR 2012 & R2 Std and Datacenter (64 bit [EM64T]), Windows SVR 2008 SP2 & R2 Std SP1, Ent and Datacenter (64 bit [EM64T]), Citrix XenApp 7.6 with Windows SVR 2008 R2 SP1 & 2012 R2 (April 2014 Updt), Citrix XenApp 7.11 with Windows SVR 2016, Citrix XenDesktop 7.6 & 7.11, Windows SVR 2012 R2 Hyper-V, Windows SVR 2016 Hyper-V, VMWare vSphere 6.0 Horizon View
You Have: Microsoft Windows 10 (build 16299), 64-bit
FREE DISK SPACE
FREE DISK SPACE
Minimum: 4 GB
You Have: 148.5 GB
MONITOR MAXIMUM RESOLUTION
Minimum: 1024 x 768
You Have: 1366 x 768
Recommended:
CPU
Recommended: Hyper-threading (HHT) or Multi-core recommended
CPU SPEED
CPU SPEED
Recommended: 2.4 GHz
VIDEO CARD
VIDEO CARD
Recommended: 256 MB video card with Shader Model 3.0
Features: Recommended attributes of your Video Card
RequiredYou Have
IconTotal Video RAM256 MB6.0 GB
IconHardware T&LYesYes
IconPixel Shader3.05.0
IconVertex Shader3.05.0
RAM
RAM
Recommended: 8 GB
You Have: 8.0 GB
OS
OS
Recommended: Windows 7 Ultimate, Pro, and Ent SP1, Windows 8.1 Basic, Pro, and Ent Sept. 2016 Updt, Windows 10 (64 bit [EM64T]) Creators Updt, Windows SVR 2012 & R2 Std and Datacenter (64 bit [EM64T]), Windows SVR 2008 SP2 & R2 Std SP1, Ent and Datacenter (64 bit [EM64T]), Citrix XenApp 7.6 with Windows SVR 2008 R2 SP1 & 2012 R2 (April 2014 Updt), Citrix XenApp 7.11 with Windows SVR 2016, Citrix XenDesktop 7.6 & 7.11, Windows SVR 2012 R2 Hyper-V, Windows SVR 2016 Hyper-V, VMWare vSphere 6.0 Horizon View
FREE DISK SPACE
FREE DISK SPACE
Recommended: 6 GB
You Have: 148.5 GB
Recommended: 1024 x 768
Well specs are good, so I don't know why you would have such a slow response.
I didn't find anything when search on 'Panasonic' either.
If it behaves that way with all tools that would just leave some environment setting.. which I can't think of any that would cause this.
