question made relevent
781
6
07-03-2018 10:30 PM
CCHSBobcats
I want a question made relevant based on yes or no answers. After doing that my form only shows the yes or no answer but not the question I want made relevant if I select yes.
SMauri
Occasional Contributor III
Hi CCHS Bobcats,
almost certainly a small error in your Excel. Create a new Survey with my this simple file and verify for yourself.
Cheers
Stefano
CCHSBobcats
Yep that works on yours. Not sure if I can replicate it for my form. I guess I understood the logic wrong when creating relevant fields.
CCHSBobcats
Ok. I added the yes no to my content tab in the sheet. That fixed it, but now I have two sets of yes and no
CCHSBobcats
Here is the form giving me two sets of yes and no now. What the heck did I do!/x.  Confused. The form only worked after I put in the
yes_noyesYes
yes_nonoNo
 Into my choices tab. From I then got my relevent code to work but it now shows up with two sets of yes and no
MatthewDobson
CCHS Bobcats In your .xlsx there are two sets of 'yes_no' options - lines 2 & 3 and lines 47 & 48.
CCHSBobcats
Awesome. Yes I had the other yes and no in my choices tab. They did not work but when added to the top of the spreadsheet they worked fine. Thank you so much!
