AnsweredAssumed Answered
Access Private Map without login
Question asked by guilherme.pigosso@hotmail.com on Jul 3, 2018
Latest reply on Jul 4, 2018 by rscheitlin
Hello all,
I'm not sure if it's possible, but we would like to access a private map without login. I'm trying to do that using the API token, but is not working very well. My code is something like:
require([
    "esri/views/MapView",
    "esri/WebMap",
    "esri/config",
    "esri/identity/IdentityManager",
    "dojo/domReady!"
], function(MapView, WebMap, esriConfig, esriId, domReady){
    esriConfig.portalUrl = "https://test.maps.arcgis.com/"
    var userToken = //get token from https://www.arcgis.com/sharing/rest/oauth2/token
    var token = {
        'server': 'https://test.maps.arcgis.com/rest/services',
        'token': userToken
    esriId.registerToken(token);
    var webmap = new WebMap({
        portalItem: {
    var view = new MapView({
        map: webmap,
        container: "viewDiv"
But is not working. The map area still blank, like if my map doesn't exists.
Any idea?
Thank you!
Outcomes
