Calculate Field Fails in ArcGIS Pro 2.2
1740
6
07-03-2018 07:15 AM
TimFast
I am running ArcGIS Pro 2.2 I have two shapefiles (ShpA and ShpB). I join ShpB to ShpA and I want to update a column in ShapA from ShpB using Calculate Field. This has worked in the past; however, now it fails with the following error:
ERROR 999999: Something unexpected caused the tool to fail. Please refer to the error help for potential solutions, or contact Esri Technical Support http://esriurl.com/support.
Cannot acquire a lock.
Failed to execute (CalculateField).
No other files are open and no other instances of Pro or desktop are running. The same procedure works fin in Desktop.
MichaelVolz
Esteemed Contributor
When you say this worked in the past, do you mean it worked in previous versions of Pro?
TimFast
Yes, however it works in the following cases:
No records are selected in either table
Records are only selected in ShpA
when records in shpB are selected and ShpA has records selected it fails
JakeSkinner
Esri Esteemed Contributor
Hi Tim,
I try to avoid using shapefiles at all cost.  Can you try importing the shapefiles into a File Geodatabase to see if you receive the same error?
JoeBorgione
^^^^^ THIS! ^^^^^^
MichaelVolz
Tim:
If you convert the shapefiles to file gdb feature classes does the field calculator work in that scenario?  I ask because I am getting the same error message with file gdbs when trying to perform a field calculation on a field in the feature class that is being populated by a field calculation from the joined table.  I have only being working with text fields thus far.
DuncanHornby
MVP Notable Contributor
I posted this question earlier this year but have had no reply. The experiences I am having with Pro seem to be mirrored by yourselves?
For what it's worth, joining excel tables and subsequent field calculates seem very flaky.
