Is there a JSON expert here? please I need help !
1165
07-03-2018 06:37 AM
IreneEgbulefu1
New Contributor III
I am trying to modify the JSon code from Esri to enable me use my offline map on my survey 123 for ArcGIS design "http://doc.arcgis.com/en/survey123/desktop/create-surveys/preparebasemaps.htm"
But I am having issues with the validation, I am just stuck on one '{'
I am not very good with JSON syntax and I need to get the syntax right for the script to work. I would appreciate if anyone can spare a few seconds to look at the script and help me find what I'm not doing right.
 "displayInfo": {
  "map": {
   "coordinateFormat": null,
   "defaultType": {
    "name": null
   "home": {
    "latitude": 30.358219056799644,
    "longitude": -97.89650653945787,
    "zoomLevel": 11.2009
   "preview": {
    "zoomLevel": 0
  "style": {
   "backgroundColor": "#bfaac8",
   "backgroundImage": null,
   "inputBackgroundColor": null,
   "inputTextColor": "#000000",
   "textColor": null,
   "toolbarBackgroundColor": "#000000",
   "toolbarTextColor": "#5500ff"
 "imagesInfo": {
  "captureResolution": 320
 "publishInfo": {
  "connectVersion": "2.8.4",
  "webFormTransform": true
 "queryInfo": {
  "applySpatialFilter": true,
  "mode": "",
  "where": ""
 "displayInfo": {
  "map": {
   "mapTypes": {
    "append": false,
    "includeLibrary": false,
    "mapSources": [{
     "name": "Steiener Ranch Test Map",
     "url": "http://traviscountytx.maps.arcgis.com/home/item.html?id=f4770fd5211c49719fa567aeae6f8435",
     "storeInMapLibrary": false
 "sentInfo": {
  "enabled": true
 "serviceInfo": {
  "itemId": "cd3fe79db7014e8db966833350bb21a2",
  "type": "Feature Service",
  "url": "https://services1.arcgis.com/HGcSYZ5bvjRswoCb/arcgis/rest/services/service_6ea10ff2bb15486aa6d943c2c..."
Here is the error from JSON Validator (Screenshot)
Screenshot of Error from JSON Validator
SMauri
Occasional Contributor III
Hi Irene,
let me ask you why you don't use this method: Include your tile package in a survey—Survey123 for ArcGIS | ArcGIS .
Here 3 simple steps:
  1. load your map (Steiener Ranch Test Map) in ArcGIS Pro
  2. create Map Tile package using this tools: Create Map Tile Package—Data Management toolbox | ArcGIS Desktop
  3. add map tile package (tpk) to the media folder in your survey's content folder before publishing
That's all...and it's more easy than editing a Json file.
Anyway...in a Json file you must have a unique "key value"...instead you have 2 "displayInfo" key in your Json
Cheers
Stefano
SMauri
Hi Irene,
Cheers
Stefano
IreneEgbulefu1
New Contributor III
Thank you so much Stefano. Your suggestions were very correct and very helpful
JamesTedrick
Esri Esteemed Contributor
As Stefano says, you have 2 'displayInfo' sections.  You should combine them together to make one section:
"displayInfo" : {
"map": {
   "defaultType": {
    "name": null
   "home": {
   "preview": {
    "zoomLevel": 0
"mapTypes": {
    "append": false,
    "mapSources": [{
