AnsweredAssumed Answered
Related records not showing in portal.
Question asked by rsm_ddms on Jun 29, 2018
Latest reply on Jul 3, 2018 by rsm_ddms
I have a straightforward relate that I set up in ArcGIS Desktop that connects properties (1) with sample results (0 to N) per property.
In the  map viewer, I can select the properties, and when I do, I see ALL records from the relate table. When I select "View Related Records" from the popups, the records disappear. I do see field headings, and I also see a label that says how many related records are selected, none of which I can see. The records just go blank.
Do relates have to be published as feature services to work in Portal? I hope not, because that would destroy the organization of the map service, but that's all I'm left with at this point.
Thank you for any assistance you may be able to provide.
Randy McGregor
Outcomes
