It is a reality that developers can use Visual Studio 2017 to interactively debug the script tools in ArcGIS Pro V2.2.0. This is clearly read and shown in the help document and the following video:
Debug Python code—ArcPy Get Started | ArcGIS Desktop
ArcGIS Pro and Python - YouTube
I spent many hours trying to make the Visual Studio 2017 debugger (Community Version) working with ArcGIS Pro without much success.
After I attached the debugger to the ArcGIS Pro process, I run the tool, then I 'll see the following error:
Source Not Available and Frame not in module:
If I Enable address-level debugging--> Show disassembly if source is not available in the Debug-->Options
I'll the following error. To be honest, I don't think this setting make any sense for Python any way.
No disassembly available. (not surprised)
The way I set up the test:
1.Create a new python project in VS 2017.
2.Set the Python Environment to ArcGIS Pro env: C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
3.Put something testing code in the .py file in the project:
- aprx = arcpy.mp.ArcGISProject("C:\RIASP II\RDA_Pro\RDA_Pro.aprx")
- m=aprx.listMaps("Current Work Space")[0]
- for lyr in m.listLayers():
- if lyr.name=="Events":
- print(lyr.name)
4. create a script tool in ArcGIS Pro and point the script to the py file mentioned in step 3.
5. In VS 2017, Debug --> Attach to Process --> Attach to : Python Code --> ArcGIS Pro
6. Run the tool created in step 4 in ArcGIS Pro
If I check the Solution Property in VS 2017, I found my source code paths are automatically put into Do not look for these source files!!!
I tried to set the Directories containing source code in the above property window and empty the Do not look for these source files box before the debug, but, after the debug attempt my source code path will be put back in the Do not look for these source files.
Have anyone else tried this and actually made it working?
ESRI help document has not been very helpful to me so far..., Microsoft help document ? you know...
At least, we can see the light at the end of the tunnel: A rich debug experience in an IDE for script tools built for ArcGIS Pro is coming...
Any advice or suggestions will be highly appreciated.
OK, Just an update.
It turns out you need to turn off the Python Exception, in the VS 2017 Debug--> Options. Then you'll be able to stop at the break point set in your source code.
I also installed Python native development tools for the Python development Workloads, but I don't know whether or not it has any effect on this outcome. Try turning off Python Exception first before installing this humongous component.
