AnsweredAssumed Answered
AGOL field calculation
Question asked by jborgion Champion on Jun 26, 2018
Latest reply on Jun 26, 2018 by jborgion
I have a hosted feature layer in AGOL of a couple hundred points.  One of the fields is called 'website' and has (of all things) the website of the given organization.  The field is populated in the form of www.somewebsite.org.
I'd like to have the user be able to click on that attribute and hyperlink to the site.  Easy enough.  if I manually edit the field to http://somewebsite.org it works.  But I don't really want to manually edit each record.
I tried the concat(,) function like this:  CONCAT(http://,website) and that fails with a syntax error.  I made the layer editiable, and then opened it in ArcMap, to try and brute force it, but it won't let me edit it there.  Whats the trick to calculating a field using the CONCAT(,) function, or, is there a better way to to do what I'm after?
Outcomes
