AnsweredAssumed Answered
Annotation in a file geodatabase  and subtype issues
Question asked by PSawyer_Chatt on Jun 26, 2018
Yes I have a couple layers that I have exported out of an sde database and I created a file geodatabase to create annotation labels within the database. Is there a shortcut to edit the labels or do I have to select each label individually to edit. Also, when I convert annotation for a larger layer for streets as a feature linked or append a overflow stack error pops up and I am missing a lot of street names. Finally,  When I convert layers from an sde database to a file geodatabase either the subtype is greyed out or I do not have the option to select a particular attribute field to use as a subtype.
Outcomes
