We have a lab where students can login on any machine. They randomly redirect to one of Citrix servers and would like to use Pro with concurrent license.
Each time a student login they gets a clean machine (they can save data to network drive but cannot install anything).
The registry key for the license is per user (Unlike ArcMap where it is for local machine).
I could not find any environment variable that can overwrite registry (unlike ARCGIS_LICENSE_FILE for ArcMap).
Is there anyway to do it without the need to set the license again when you login?
Maybe a batch file that will set the user registry key when login?
Mody,
You can use the environment variable, ARCGIS_LICENSE_FILE_PRO for ArcGIS Pro. As a matter a fact, most of the environment variables for ArcGIS Desktop has an ArcGIS Pro equivalent. Just add the PRO suffix to existing Desktop features. Let us know if you find one you need that does not work for Pro.
