I'm trying to download a bunch of photos off of Survey123 (preferably attached to the data from each survey). I've been trying to run the script published here How To: Batch export attachments from a feature class but I keep getting error messages. Has anyone found a fix for this problem or know how to tweak the script? James Tedrick
Hi Rose,
The error message you are receiving is a bit unusual - it looks as if your python file was saved as the wrong type of file (txt vs py). This might happen if your Windows Explorer normally hides the file extensions (.docx, .txt, .xls, etc.) - the you name the file you may not have actually given it the correct extension.
