ArcGIS Online Cluster Points
1051
06-22-2018 02:02 PM
warrenroberts
Occasional Contributor II
I have addresses I like to cluster and have the point count display above and it works great thru the ArcGIS Excel interface as shown in image but when shared to Arcgis online or performed instead in ArcGIS Online ,you can cluster (not as nice however) but you dont have the number values as shown in image?  any suggestions?
KellyGerrow
Esri Frequent Contributor
Hi Warren,
You should be able to tell the size of clusters based on the pop up and the size as outlined in the legend in ArcGIS Online. Currently there isn't functionality to show the specific number of items as the same information is available through two other ways. Would either of these work for the map that you are creating.
-Kelly
warrenroberts
Thank you! to confirm, the Excel interface does provide this only ...  but not the arcgis online?  The display shows the Ecel map (and is shared public ally) ... but again to confirm, this is not visible in this fashion (cartographically)  if viewed anywhere but in Excel Esri Office?  Thank you for such as quick response!
KostiaLesik
Does acgis online still not support showing cluster size inside the cluster point?
