Hi All
When you try to jump to a new coordinates it uses locator in AGOL.
I understand it can be done with local portal/server (how?).
Is there any way to do it without any server, maybe with the API?
It is very simple functionality
Hi Mody,
Thanks for your question.
ArcGIS Earth has a built-in `search engine` which will also work on disconnected env (only support coordinate inputs). And If the input is XY coordinate,earth will use this `search engine` to locate the position rather than locator in AGOL or Portal.
For now, earth doesn't support locate an address on disconnected env.
Hope the information will help you.
Hi Ben
It does not work for me.
I use 1.6, unplug my computer from the web and start ArcGIS Earth.
Then when I type 30,60 it just become red and nothing happened.
What do I miss?
Hi Ben
Install 1.7 fixed it.
Glad to hear that the problem has been solved!
