I dont see a space for ArcGIS Server 10.5.1... only this space for Prior to 10.0
Is there a way (in ArcGIS Server 10.5.1) that I can run a report that will list out the Root...Group..Services of my server instance with their corresponding Services
Example: Listing the Root, Service, and RestEndpoints (Map, KML, Feature) for each Root Site in the Server Instance.
Public
- BirdingWildlifeTrail
- https://vxxxxx/arcgis/rest/services/Public/BirdingWildlifeTrail/MapServer
- https://vxxxxx/arcgis/rest/services/Public/BirdingWildlifeTrail/MapServer/KmlServer
- https://vxxxxx/arcgis/rest/services/Public/BirdingWildlifeTrail/FeatureServer
- BoatAccessSites
- https://vxxxxx/arcgis/rest/services/Public/BoatingAccessSites/MapServer
- https://vxxxxx/arcgis/rest/services/Public/BoatingAccessSites/MapServer/KmlServer
- https://vxxxxx/arcgis/rest/services/Public/BoatingAccessSites/FeatureServer
SandBox
- Testing
- https://vxxxxx/arcgis/rest/services/Public/Testing/MapServer
- https://vxxxxx/arcgis/rest/services/Public/Testing/MapServer/KmlServer
- https://vxxxxx/arcgis/rest/services/Public/Testing/FeatureServer
I see that there is quite a bit of info and xml files that I can datamine here: C:\arcgisserver\
But not sure where to find the information I am seeking...if its even there.
again trying to list Every Root Site - With the Service Names and the RestEndPoints for each of the services (map, KML, Feature) See my initial post for this format.
Any thoughts?
Jay, I believe System Log Parser could be useful to you: https://arcgismonitor.maps.arcgis.com/home/item.html?id=dacebd64a0a04c87b1c48905e2cfc70d
This is basically a handy tool which generates an excel spreadsheet report of all of your ArcGIS Server Services (names, min/max instances, etc.).
Alternately, you could use a python script for the purpose just as this one: Example: Write properties of all services to a CSV file—ArcGIS Server Administration (Windows) | Arc...
Earl
Im confused on the MongoDB. Is this installed locally?
Hi Jay - forget about the ArcGIS Monitor branding on the page for a moment. System Log Parser was (and still is) a standalone executable. For a better description of what the tool does see this page: https://www.arcgis.com/home/item.html?id=90134fb0f1c148a48c65319287dde2f7 - really all that's happened here is that the download page has changed. No MongoDB required.
Hi jay kapalczynski,
There is a rest endpoint to call from arcgis admin site to get list of services in json format.
Lets assume your arcgis manager url is https://[domain]/arcgis/manager
The url format is
https://[domain]/arcgis/admin/services?f=json (this is for root folder)
https://[domain]/arcgis/admin/services/[subfolder]?f=json (this is for sub folder)
If your environment is federated, you shall need to generate the token first.
If you want to perform report programmatically, append the query with [token] query string.
