Unable to add service to Portal folder
1002
06-11-2018 10:38 AM
EricPfirman
New Contributor III
I am trying to add a map service to my Portal with the ArcGIS API for Python. It works fine if I add it to the root folder but if I try to add it to a different folder it says "User folder does not exist". Obviously it exists because I just created it 2 lines earlier. I am able to do this from the Portal manager, just not from Python. Any idea what I am doing wrong?
from arcgis.gis import GIS
gis = GIS("myportal", "myaccount")
content = gis.content
content.create_folder('Basin', owner='myaccount')
properties = {
'title':'title',
'type':'Map Service',
'url':'https://.../MapServer',
'description':'description',
'tags':'tags'
item = content.add(item_properties=properties, owner='myaccount', folder='Basin')
Tags (3)
JakeSkinner
Esri Esteemed Contributor
Hi Eric,
What version of the ArcGIS API for Python are you running?  You can check by going to ArcGIS Pro > About ArcGIS Pro > Python tab > Installed Packages > arcgis.
I tested this with 1.2.5 and ArcGIS Enterprise 10.6 and it worked successfully.
Also, are you receiving an error?
EricPfirman
New Contributor III
Thanks Jake.
ArcGIS API for Python version 1.2.5
ArcGIS Enterprise 10.5
Here is the full error message
RuntimeError                              Traceback (most recent call last)
<ipython-input-14-5dbe45519908> in <module>()
16     'tags':'tags'
17 }
---> 18 item = content.add(item_properties=properties, owner='myaccount', folder='Basin')
19
20
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py in add(self, item_properties, data, thumbnail, metadata, owner, folder)
1907                 item_properties['tags'] = ",".join(item_properties['tags'])
1908
-> 1909 itemid = self._portal.add_item(item_properties, data, thumbnail, metadata, owner_name, folder)
1910
1911         if itemid is not None:
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\portalpy.py in add_item(self, item_properties, data, thumbnail, metadata, owner, folder)
318
319         path += '/addItem'
--> 320 resp = self.con.post(path, postdata, files)
321         if resp and resp.get('success'):
322             return resp['id']
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py in post(self, path, postdata, files, ssl, compress, is_retry, use_ordered_dict, add_token, verify_cert, token, try_json, out_folder, file_name, force_bytes, add_headers)
1129                 elif errorcode == 498:
1130                     raise RuntimeError('Invalid token')
-> 1131 self._handle_json_error(resp_json['error'], errorcode)
1132                 return None
1133         except AttributeError:
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py in _handle_json_error(self, error, errorcode)
1149
1150         errormessage = errormessage + "\n(Error Code: " + str(errorcode) +")"
-> 1151 raise RuntimeError(errormessage)
1152
1153 class _StrictURLopener(request.FancyURLopener):
RuntimeError: User folder does not exist.
(Error Code: 400)
EricPfirman
New Contributor III
I figured out the problem. If I include owner='' then it doesn't work. If I omit it, it does.
So this does not work:
but this does:
item = content.add(item_properties=properties, folder='Basin')
