Pro:How to check if domain exists, if not, do something else skip
8620
13
06-10-2018 11:35 AM
ThomasColson
I'm attempting to use py to check if a domain exists, if not, create it, else do nothing. After consulting How do I check if a domain already exists? , arcgis 10.0 - Using arcpy.Exists for domains? - Geographic Information Systems Stack Exchange , and esri geodatabase - Checking if domain already exists using ArcPy? - Geographic Information Systems S... I came up with the attached code. If neither domain exists, it fails with:
Start Time: Sunday, June 10, 2018 2:28:13 PM
Running script Add Extended Core Fields...
Failed script Add Extended Core Fields...
 File "C:\Temp\PRO_FOLDER_STRUCTURE\EXTENDED_CORE_FIELDS.py", line 24, in <module>
 arcpy.CreateDomain_management(gdb_name, "DOM_YES_NO_UNK_NPS2016", "Is the feature physically observable", "TEXT", "CODED")
 File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 1332, in CreateDomain
 raise e
 File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 1329, in CreateDomain
 retval = convertArcObjectToPythonObject(gp.CreateDomain_management(*gp_fixargs((in_workspace, domain_name, domain_description, field_type, domain_type, split_policy, merge_policy), True)))
 File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 496, in <lambda>
 return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
 ERROR 000192: Invalid value for Domain Name
Failed to execute (CreateDomain).
 Failed to execute (AddExtendedCoreFields).
Failed at Sunday, June 10, 2018 2:28:14 PM (Elapsed Time: 1.52 seconds)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
However it creates the domain!
If I run it again knowing the domain exists, same error message.
import os
import errno
import arcpy
#Get user input
gdb_name = arcpy.GetParameterAsText(0)
fc_name = arcpy.GetParameterAsText(1)
isOBSERVABLEchecked = arcpy.GetParameterAsText(2)
isISEXTANTchecked = arcpy.GetParameterAsText(3)
#Create the Optional OBSERVABLE domain
if str(isOBSERVABLEchecked) == 'true':
        existingDomains = arcpy.da.ListDomains(gdb_name)
        isthere = False
        for domain in existingDomains:
                if domain.name == 'DOM_YES_NO_UNK_NPS2016':
                        isthere = True
                        break
                if isthere == False:
                        YESNODict = {"Unknown":"Unknown", "Yes": "Yes", "No": "No"}
                        for code in YESNODict:
                                arcpy.AddCodedValueToDomain_management(gdb_name, "DOM_YES_NO_UNK_NPS2016", code, YESNODict[code])
                else:
                        arcpy.AddMessage("DOM_YES_NO_UNK_NPS2016 already exists")
#Create the Optional ISEXTANT domain
if str(isISEXTANTchecked) == 'true':
        isthere = False
                        isthere = True
                        break
                                arcpy.CreateDomain_management(gdb_name, "DOM_ISEXTANT_NPS2016", "Indicates feature or features that are no longer in existence or partially in existence.", "TEXT", "CODED")
                                ISEXTANTDict = {"Unknown":"Unknown", "True": "True", "False": "False", "Partial": "Partial", "Other": "Other"}
                                for code in ISEXTANTDict:
                                        arcpy.AddCodedValueToDomain_management(gdb_name, "DOM_ISEXTANT_NPS2016", code, ISEXTANTDict[code])
                else:
                        arcpy.AddMessage("DOM_ISEXTANT_NPS2016 already exists")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
As best as I can tell, I have an illegal loop condition that keeps trying to create the first domain whether it exists or not, and the failure stems from the domain name already exists.
DanPatterson_Retired
A quick look
You might use a 'try except' block.  If you 'try' to see if it exists and it fails, it will go to the except block (there are variants like try-except-else-finally
ThomasColson
Dan, with something like below, I'm getting nothing....
import os
import errno
import arcpy
#Get user input
isOBSERVABLEchecked = arcpy.GetParameterAsText(1)
isISEXTANTchecked = arcpy.GetParameterAsText(2)
try:
        #Create the Optional OBSERVABLE field
                isthere = False
                                isthere = True
                                break
                                #arcpy.AddField_management(fc_name, "OBSERVABLE", "TEXT", "", "", 20, "OBSERVABLE", "NULLABLE", "NON_REQUIRED", "DOM_YES_NO_UNK_NPS2016")
                                #arcpy.AssignDefaultToField_management(fc_name, "OBSERVABLE", "Unknown")
                        else:
        else:
                arcpy.AddMessage("OBSERVABLE field not created")
        #Create the Optional ISEXTANT field
                isthere = False
                                isthere = True
                                break
                                        arcpy.CreateDomain_management(gdb_name, "DOM_ISEXTANT_NPS2016", "Indicates feature or features that are no longer in existence or partially in existence. If data represents features that are no longer in existence or only partially in existence following damage, disaster or some other change to its statusthen the value will be false or partial (Cultural Resources, 2014).", "TEXT", "CODED")
                                        #arcpy.AddField_management(fc_name, "ISEXTANT", "TEXT", "", "", 20, "ISEXTANT", "NULLABLE", "NON_REQUIRED", "DOM_ISEXTANT_NPS2016")
                                        #arcpy.AssignDefaultToField_management(fc_name, "ISEXTANT", "Unknown")
                        else:
        else:
                arcpy.AddMessage("ISEXTANT field not created")
except arcpy.ExecuteError:
    print(arcpy.GetMessages(2))
not sure why you have a break on line 41 I would suspect you would want to continue your checks.  And on line 42, it is generally not recommended to do an equality check for booleans.  Just use
if isthere:   # is it there  This is the True case
or
if not isthere:  # this is the False case
It reads better if you use 'present'  then you get 'if present: ' and 'if not present'
ThomasColson
Dan not sure what you meant in above (I didn't take your Python class!), but this is what I think you meant, which, creates the domain if it doesn't exist, but if the domain exists, just runs successfully with no exit reporting domain already exists....
import os
import errno
import arcpy
#Get user input
try:
                isthere = False
                                isthere = True
                        else:
        else:
                arcpy.AddMessage("OBSERVABLE domain not created")
At this stage, I would put in as many print statements as you can muster, since nothing is throwing an error, but you don't know if it doing nothing or not getting to where something is being done
ThomasColson
In trying to isolate what's not working, I get this far. I've not set up the loop correctly...?I just want to check if the condition exists, print "exists", else print "it doesn't exist", where the condition is being checked against a list of domains:
                print("DOM_YES_NO_UNK_NPS2016 already exists")
        else:
                print("creating domain")
creating domain
creating domain
creating domain
creating domain
creating domain
Thomas... let's collect information on bit at a time.
  • since nothing is throwing an error, dump the try except block
  • existingDomains = arcpy.da.ListDomains(gdb_name)
  • domain_names = [i.name for i in existingDomains]
  • print(domain_names)
what does that print?
ThomasColson
['DOM_REGIONCODE_NPS2016', 'DOM_PUBLICDISPLAY_NPS2016', 'DOM_DATAACCESS_NPS2016', 'DOM_XYACCURACY_NPS2016', 'DOM_YEffS_NO_UNK_NPS2016', 'DOM_YES_NO_UNK_NPS2016']
Which is the same as
print(domain.name)
RandyBurton
You are looping through all domain names (around line 18 - for domain in existing...) and, since some of them will not match (at the next line), it will try to insert the new domain anyway.
Try setting up your loop like this:
gdb_name = r"C:\Path\To\file.gdb"
chkDomains = [
             ['DOM_YES_NO_UNK_NPS2016', {"Unknown":"Unknown", "Yes": "Yes", "No": "No"} ],
             ['DOM_ISEXTANT_NPS2016', {"Unknown":"Unknown", "True": "True", "False": "False", "Partial": "Partial", "Other": "Other"} ]
dn = []
for domain in existingDomains: # get list of domain names
    dn.append(domain.name)
for chk in chkDomains:
    if chk[0] in dn: # see if it is in list of domain names
        print "Domain {} exists".format(chk[0])
    else:
        print "Adding domain {} using dictionary {}".format(chk[0], chk[1])‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
