How to change coordinate system for .tpk file?
3110
5
06-11-2018 01:48 AM
VijitWadhwa
New Contributor III
I tried to create a .tpk file from ArcGIS Desktop, taking the data reference as one of my custom projection system, but when i try to load it in runtime , it is not visible.The .tpk file is visible ony if i set the spatial refernce of map as Web marcator. How can i fix this ?? Hoping for a solution, Thanks in advance  Melita Kennedy
Vijit
dotMorten_esri
Esri Notable Contributor
You cannot change the spatial reference of tile packages. You'd have to generate a new TPK in the spatial reference you need.
VijitWadhwa
New Contributor III
(correction) * sorry i mean data frame
dotMorten_esri
VijitWadhwa
New Contributor III
How can I change the projection of tile layer while creating .tpk file ? As
there is no option in ArcGis desktop to add projection while creating .tpk
file ?
dotMorten_esri
I believe you change the map's projection first, before generating the TPK:
ArcGIS Help 10.1
VijitWadhwa
New Contributor III
Sir , I changed the projection of data frame with my own projection , but
after creating .tpk file , the tile layer takes the projection of Web
Marcator
