Survey Duplication
527
06-07-2018 11:37 AM
ReedShoho1
Can you duplicate a survey? Are there options available for survey duplication (i.e. creating a new instance of a survey) in REST?
JamesTedrick
Esri Esteemed Contributor
Hi Reed,
Surveys can be duplicated via the Survey123 web page or Survey123 Connect.  It is possible to duplicate a survey programmatically; the main consideration will be to ensure the .iteminfo file's contents is deleted, as that holds information on the form as published in an organization.
