AnsweredAssumed Answered
Can I open the layout properties dialog programmatically?
Question asked by amikelson on Jun 7, 2018
Latest reply on Aug 21, 2018 by jbarrette-esristaff
Following is the code I am attempting to use to open the layout properties dialog programmatically:
var command = FrameworkApplication.GetPlugInWrapper(@"esri_layouts_projectItem_LayoutProperties") as ICommand;
if (command != null)
// get the layout project item
var layoutItem = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(item => item.Path.Equals(this.LayoutUri));
if (layoutItem != null)
if (command.CanExecute(layoutItem))
command.Execute(layoutItem);
If I change the parameter for the GetPlugInWrapper to "esri_layouts_layoutPropertiesButton", I can open the layout properties for the currently active layout pane, however that is not what I am looking to do.
What do I need to pass into the command.CanExecute parameter to use the "esri_layouts_projectItem_LayoutProperties" button?
Thank you,
Tony
Outcomes
