ArcGIS Network Analyst Route Optimization cannot solve
443
06-06-2018 12:38 AM
VyTu
Hi everyone, I'm new to ArcGIS and I'm having problem using the Network Analyst extension. I want to find the shortest driving path from multiple points to a plant.
I obtained the road shapefile from OpenStreetMap via Bbbike extract. The network dataset created from that shapefile has 3 attributes: Length (costs), Minutes (costs), Oneway (restriction).There is only global turns as the turn source, the restricted turns is not available. The hierarchy is also not available.
I tried both to load locations from my .cvs file and select the stops myself but it shows the message below
Does anyone know what is missing here? Is it becasue of the road network dataset? do I need to create a turn feature class?
DanPatterson_Retired
Did you go throught the whole procedure of preparing the roads for use as a network dataset and how to load your stops etc?
This is the start of the PRO tutorials
http://pro.arcgis.com/en/pro-app/help/analysis/networks/route-tutorial.htm
