AnsweredAssumed Answered
Qlik Sense - Esri Integration (Esri Extension)
Question asked by lntinfotechmfg2 on Jun 4, 2018
Latest reply on Oct 12, 2018 by jamirola
I have integrated esri webmap with qlik sense using arcgis javascript api 3.8. I have downloaded the source code from github.
Now, i want to migrate it to arcgis javascript api 4.7. But, map is not loading. getting invalid visualisation error. Herewith i have attached my code.
require.config({
paths: {
"components": "https://rawgit.com/johsund/QlikESRIGit/master/bower_components", //"http://localhost:4848/extensions/QlikSenseESRI/bower_components",
"dojo": "https://rawgit.com/johsund/QlikESRIGit/master/bower_components/dojo", //"http://localhost:4848/extensions/QlikSenseESRI/bower_components/dojo",
"dijit": "https://rawgit.com/johsund/QlikESRIGit/master/bower_components/dijit", //"http://localhost:4848/extensions/QlikSenseESRI/bower_components/dijit",
"dojox": "https://rawgit.com/johsund/QlikESRIGit/master/bower_components/dojox", //"http://localhost:4848/extensions/QlikSenseESRI/bower_components/dojox",
//"esri": "https://js.arcgis.com/3.8/js/esri"
"esri": "https://js.arcgis.com/4.7/esri"
define( [
'jquery',
'text!./template.html',
'text!./css/esri.css',
'qvangular',
'js/qlik',
"esri/views/MapView",
"esri/WebMap",
"dojo/_base/Color",
"dojo/_base/array",
"dojo/dom",
"dojo/on",
"dojo/domReady!"
], function ( $, template, cssContent, qv, qlik, MapView, WebMap, Color, arrayUtils, dom, on) {
'use strict';
$("<style>").html(cssContent).appendTo("head");
//Legend widget
var legendDijit, position;
return {
paint: function ( $element, layout ) {
// GETTING THE DATA FROM Qlik
this.backendApi.cacheCube.enabled = false;
var _this = this;
var columns = layout.qHyperCube.qSize.qcx, totalheight = layout.qHyperCube.qSize.qcy;
var pageheight = Math.floor(10000 / columns);
var numberOfPages = Math.ceil(totalheight / pageheight);
var markers = [];
var selectedMarkers = [];
var dimensions = layout.qHyperCube.qDimensionInfo;
var columns = layout.qHyperCube.qSize.qcx;
var totalheight = layout.qHyperCube.qSize.qcy;
var Promise = qv.getService('$q');
var promises = Array.apply(null, Array(numberOfPages)).map(function(data, index) {
var page = {
qTop: (pageheight * index) + index,
qLeft: 0,
qWidth: columns,
qHeight: pageheight
return this.backendApi.getData([page]);
}, this)
$element.html(template);
Promise.all(promises).then(function(d) {
render(d);
function render(d) {
var webmap = new WebMap({
portalItem: { // autocasts as new PortalItem()
var view = new MapView({
map: webmap,
container: "mapDiv"
var map = new Map({
basemap: "topo"
container: "mapDiv",
map: map,
scale: 2400000
}; //render
} //paint
Please help me to migrate to arcgis javascript api 4.7
Outcomes
