ERROR 000732 on executing TableToTable
1854
10
06-04-2018 05:58 AM
AndreasRuloffs1
New Contributor III
Hi there,
I am facing a strange Problem. In the following Script two Tables in an sql-Server Database should be exported.
The first one works, the second one not (I am sure it is spelled right).
import tempfile
import arcpyout
Location = tempfile.mkdtemp()
arcpy.TableToTable_conversion("../bamo.sde/bko.bkEingriffart",outLocation, "bkEingriffart.dbf")
arcpy.TableToTable_conversion("../bamo.sde/bko.bkMassnahmenbkMassnahmenZiele",outLocation, "bkMassnahmenbkMassnahmenZiele.dbf")‍‍‍‍‍‍‍‍‍‍
I got the Error:
File "C:\Users\xxx\.p2\pool\plugins\org.python.pydev_5.7.0.201704111357\pysrc\pydevd.py", line 1546, in <module>
globals = debugger.run(setup['file'], None, None, is_module)
File "C:\Users\xxx\.p2\pool\plugins\org.python.pydev_5.7.0.201704111357\pysrc\pydevd.py", line 982,
in run    pydev_imports.execfile(file, globals, locals)  # execute the script
File "C:\Repositories\Python\bkonline2-deploy\gp-services\bko\exportSHP.py", line 13, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\conversion.py", line 2133, in TableToTable
raise earcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Rows: Dataset ../bamo.sde/bko.bkMassnahmenbkMassnahmenZiele does not exist or is not supportedFailed to execute (TableToTable).‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I use ArcGIS 10.3.1 for develpoing, but the error also occurs when using ArcGIS 10.5.1.
Later the Script shell run as a geoprocessing Task on an ArcGIS for server.
Has anybody an idea?
Best Regard,
Andreas
JoeBorgione
To me it looks like you are missing a comma and some parentheses
# yours :  import tempfileimport arcpy
import tempfileimport, arcpy   #note comma...
# yours:  arcpy.TableToTable_conversion("../bamo.sde/bko.bkMassnahmenbkMassnahmenZiele",outLocation, "bkMassnahmenbkMassnahmenZiele.dbf")
arcpy.TableToTable_conversion(("../bamo.sde/bko.bkMassnahmenbkMassnahmenZiele",outLocation, "bkMassnahmenbkMassnahmenZiele.dbf"))  # note enclosing parentheses...
 Just a WAG  (wild a$$ guess...)
AndreasRuloffs1
New Contributor III
Thank you Joe,
some new Lines got missing, I correct that.
I do not understand the part with the parantheses TableToTable_conversion works with a single Table.
JoeBorgione
My apologies Andreas- when I first read your post I thought I saw that you were using the output of a second TableToTable function as input to a first TableToTable function.  Your use of relative paths may be problematic as well.
I'm not familiar with the use of tempfile, so my approach would be to set the out put workspace as an arcpy env variable:
import arcpy
from arcpy import env
arcpy.env.workspace = r'DriveLetter:\your\desired\path\to\output\directory'
out_ws = arcpy.env.workspace
# use a complete path to your sde connection and file name
# below is an example of one of mine
in_table = r'T:\GIS Documents\AddressPOC2017\AddIn\SLCOGIS_Joe.sde\SLCOGIS.GDB_ADD.DB2_StreetFile'
out_table = 'YourNameOfChoice.dbf'
arcpy.TableToTable_conversion(in_table,out_ws,out_table)
AndreasRuloffs1
New Contributor III
Unfortunately this makes no difference.
JoshuaBixby
MVP Esteemed Contributor
What if you comment out the first table conversion, does the second one (now the first) err out?  It is good to isolate whether it is the call itself or calling something successively that is causing an issue.
AndreasRuloffs1
New Contributor III
If I comment out the first T2T conversion, then the second one fails anyway.
JoshuaBixby
How is bkMassnahmenbkMassnahmenZiele different than bkEingriffart in terms of structure, e.g., is one a feature class and the other one a table?
If both are just tables, my money is on permissions.  If the T2T tools can't open the table to read it, it will report it does not exist or is not supported.
AndreasRuloffs1
New Contributor III
bkEingriffart is just a simple table, bkMassnahmenbkMassnahmenZiele  is a table to resolve an m to n relationship. Therefor it has a composite primary key.
AronSaylor
I am having issues similar to this. Was your issues ever resolved?
