ModuleNotFoundError: No module named 'arrow'
4611
06-04-2018 08:56 AM
JayHodny
Occasional Contributor III
I have been working with ArcGIS for Workforce and the 'create assignment from csv' script.  I had the script working well, then my laptop was upgraded, and now the script won't run.  I updated the 'arcgis' version to 1.4.1.  I am using Pro 2.1.3.  My project environment is: C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3.  I am fairly new to Python and running scripts, so chalk one up to operator error!  I don't know how to resolve this.  Is there a way to uninstall 1.4.1 and then reinstall?  Or a way to check that 1.4.1 was installed correctly?
JayHodny
My IT group and I were able to use conda to install arcgis and arrow, and the script is now working.
JayHodny
The uninstall button is grayed out in the Pro Python back end screen.  If I try to upgrade, I get a message saying the version 1.4.1 is already installed.
JayHodny
KonradHughes
I've just encountered this same problem, but I'm having problems duplicating your solution.  I get the same error with the same script, in spite of having used conda to install arrow.  Could you help me in a little more detail?
JayHodny
Hi Konrad, This issue occurred awhile ago for me, so recollection of the details is not good now.  Once we got back up and running, I let the process slip from my memory.  I was getting this error (see screenshot).  I had to have one of our IT admins figure out how to update package.  I know we had to use conda to install, and it took a couple of attempts before the update stuck, and arrow module was installed.  I have not run the Workforce csv assignment script in quite awhile, so I am assuming it still functions with the latest Pro version installed.  I am sorry I am not much help. Sincerely,
Jay
