Highlight the related attribute with color based on selected PIN
784
10
06-04-2018 06:10 AM
G_KrishnaRao
Hello..
I have black dots i.e (Assets) in Map page and each asset has different Asset ID.
My requirement is when i select the PIN in the map, the respective asset id's in map should get highlighted with any color.
My Problem is I am unable to read/identify the asset based on the selection.Therefore i am unable to highlight any color on the same.
I have tried a lot but not get success.
Any help is appreciated.
Thanks in advance.
KenBuja
MVP Esteemed Contributor
Can you post the code of what you've tried so far?
G_KrishnaRao
HI,
Thanks for the reply.
Please find the attached function which is written in ARCGISMap.JS Page
KenBuja
What are the objects in "data" that are getting returned by the ajax query? Are they features or something else? If they are features, normally you would find the attributes by
assetid = data[i].attributes.AssetID
You should use the debugger tools in your browser to examine the "data" object to determine where the attributes are stored.
What are the AssetIDs? You're trying to create graphics from the splitassetsids, but creating graphics requires either a geometry or a JSON object. You're then trying to add splitassetsids to the map directly, not the graphics you tried to create.
Finally, you're mixing up using AMD and legacy-style coding.
var sls = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color(markerHighlightColor), 4);
var polyGraphic = new esri.Graphic(splitassetids, symbol);
You should use just AMD style.
G_KrishnaRao
Please find the document(attached).
KenBuja
Please just write your comments in this thread, not in a separate document attachment.
How are the black dots added to the map? Are they a separate feature layer or just graphics? It's difficult to diagnose without seeing more of your code
G_KrishnaRao
Sorry for the delayed response.
As per current update, i am now able to highlight the assets on pin click.
But now, the problem is highlight part is working only after doing zoom in
or zoom out in map.
I mean, when i am selecting any PIN then after doing zoom in or zoom out
the color is highlighting on the assets.
Is there any workaround, where i can click on PIN and highlight the asset
color without zoom in or zoom out.
Awaiting for your reply.
Thanks in advance.
G_KrishnaRao
HI ,
Hope you are doing well.
Any workaround for my previous issue.?
On Thu, Jun 7, 2018 at 1:45 PM, JustLikeThat GK <krishnadew06@gmail.com>
KenBuja
What is your code?
G_KrishnaRao
Greetings for the day.
Here is the code attached.
on PIN click,after zoom in or zoom out the map then only i am able to see
the highlighted color.
I want to avoid zoom in and zoom out. Just on PIN click only the related
assets should be highlighted .
