Blanks in a Label
1939
8
06-01-2018 09:02 AM
KennethRichards
New Contributor III
What is a good way to skip a blank field when creating label expressions? I have a bunch of points that I need labeled with data from multiple fields but some contain blanks. I am working in ArcPro if that makes any difference.
DanPatterson_Retired
what labelling method are you using? standard or maplex? What types of the fields are involved? labelling language?
Perhaps some examples from your case.
In essence, you can create a labelling function that will use the inputs from fields and translate any nulls to an empty string prior to concatenation
http://pro.arcgis.com/en/pro-app/help/mapping/text/specify-text-for-labels.htm
XanderBakker
Esri Esteemed Contributor
Can you share an example of a label including blank fields and what you want to have as a result? There are multiple ways to achieve this and an example will make it easier to suggest a good way to do this.
KennethRichards
New Contributor III
Attribute TableAttribute Table 2
I am using Maplex. The fields are text fields.
Map
The Popup2 field has blanks in that I want to omit when I generate the labels. The red arrows are the blanks I am trying to remove.
Right now I am using a basic expression to create them.
[Name2] +  '\n'  +  [PopUp2] +  '\n'  + [DMSLat] +  '\n'  + [DMSLong]
Thanks for taking the time to help.
A demo... a, b, c, d represent field names
they need to be replace with !YourFieldName! in ! marks
Python parser
could be used in a field calculation and I presume in some labeling thing (don't do much mapping with labels, so I will defer to those that do)
a, b, c, d = ['a', '', 'c', 'd']
def prn(a, b, c, d):
    """demo replace the letters with !YourFieldName!
    if b not in ("", " ", None):
        frmt = "{}\n{}\n{}\n{}".format(a, b, c, d)
    else:
        frmt = "{}\n{}\n{}".format(a, c, d)
    return frmt
prn(a, b, c, d)
'a\nc\nd'
print(prn(a, b, c, d))
a
c
d
XanderBakker
... and since you can use Arcade too for the labeling, find an example below:
var Name2 = "FR-20";
var PopUp2 = null;
var DMSLat = "37°32'5.460\"N";
var DMSLong = "113°4'53.641\"W";
// var Name2 = $feature.Name2;
// var PopUp2 = $feature.PopUp2;
// var DMSLat = $feature.DMSLat;
// var DMSLong = $feature.DMSLong;
var array = [Name2, PopUp2, DMSLat, DMSLong];
var result = "";
for (var i = 0; i < Count(array); i++ ){
    if (IsEmpty(array[i]) == false) {
        if (result == "") {
            result = array[i];
        } else {
            result = result + "\n" + array[i];
return result;
On lines 1 to 4 I'm setting some values hard coded. Lines 6 to 9 show how these values can be read from the fields.
This will yield the label without the empty line:
KennethRichards
New Contributor III
I will try this one. I have been wanting to learn Arcade a little more.
XanderBakker
forgot this missive....
*args would require some field names of indeterminate length
ie prn(!A!, !b!, !cc!, !d!) as the expression
def prn(*args):
    vals = [i for i in args if i not in ("", " ", None)]
    frmt = ("{}\n"*len(vals)).format(*vals)
    return frmt
print(prn(a, b, c, d))  # in the order given
a
c
d
print(prn(a))  # a singleton
a
print(prn(a, d, c, b))  # switch them up
a
d
c
But if you want to change the separator, you can use this variant
# --- requires python 3.6 or above
def prn(*args, sep="..."):
    vals = [f"{i}"+sep for i in args if i not in ("", " ", None)]
    frmt = ("{}"*len(vals)).format(*vals)
    return frmt
prn(a, c, d)
'a...c...d...'
# ---- change sep="\n" for newline instead
