AnsweredAssumed Answered
Collector Workflow
Question asked by afabrizi on May 31, 2018
I am in the process of creating an inspection workflow.  Due to constraints of Collector and Survey123, we're using Survey123 for the inspection form, and Collector for the map.  We would prefer to use the AssetID (guid) to relate the Asset and the inspection form.  I found that text within a [text] field inside of Collector can be copied from there to Survey123.  When i went to test this on the guid field, this field is not present inside of Collector, even though it is turned on inside of the web map.  I can use the Object ID but would prefer the AssetID.
Is there anyway to view the guid inside of Collector?
Thanks!
Collector 18.0.1.0
Survey123 2.8.2
Portal 10.5.1
Outcomes
