Easiest way to label a dynamic service layer
2455
11
05-29-2018 08:55 PM
BrandonPrice
What is the least complex way to label a arcgisdynamic service layer that is using a map service comprised of two grids covering two counties with a minzoom of 40000? The label would be the id for each grid. Let me know if more information is needed.
RobertScheitlin__GISP
Brandon,
Here is a sample.
<!doctype html>
<html>
<head>
  <meta charset="utf-8">
  <title></title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.24/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.24/esri/css/esri.css" />
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #map {
      margin: 0;
      padding: 0;
  </style>
  <script src="https://js.arcgis.com/3.24/"></script>
  <script>
    var app = {};
    require([
        "esri/map", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/LayerDrawingOptions", "esri/layers/LabelClass", "esri/symbols/TextSymbol",
        "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function (
      Map, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
      LayerDrawingOptions, LabelClass, TextSymbol, parser
      parser.parse();
      app.dataUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2";
      app.defaultFrom = "#ffffcc";
      app.defaultTo = "#006837";
      app.map = new Map("map", {
        center: [-85.787, 39.782],
        zoom: 9,
        slider: false
      var basemap = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer");
      app.map.addLayer(basemap);
      var ref = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Reference_Overlay/MapServer");
      urlDyn = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer";
      usaLayer = new ArcGISDynamicMapServiceLayer(urlDyn, {
        opacity: 0.7,
        visible: false
      usaLayer.setVisibleLayers([2]);
      app.map.addLayer(usaLayer);
      var optionsArray = [];
      var drawingOptions = new LayerDrawingOptions();
      var labelClass = new LabelClass({
        labelExpression: '[' +  "POP2000" + ']',
        labelPlacement: 'esriServerPolygonPlacementAlwaysHorizontal',
        symbol: new TextSymbol(),
        minScale: 840000
      drawingOptions.labelingInfo = [labelClass];
      drawingOptions.showLabels = true;
      optionsArray[2] = drawingOptions;
      app.map.getLayer("us_counties").setLayerDrawingOptions(optionsArray);
      app.map.getLayer("us_counties").show();
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
    </div>
  </div>
</body>
</html>
Brandon,
Here is a sample.
<!doctype html>
<html>
<head>
  <title></title>
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #map {
      margin: 0;
      padding: 0;
  </style>
  <script>
    var app = {};
    require([
      ], function (
      parser.parse();
        zoom: 9,
        slider: false
        opacity: 0.7,
        visible: false
        minScale: 840000
  </script>
</head>
    </div>
  </div>
</body>
</html>
BrandonPrice
my version is as follows:
Both set visible layers in the array are shown in the map although the label only shows for the 3rd layer in the array. Also the halo settings are not shown. What am I missing?
urlDyn = "https://sv07gdchfeat10.ct.dot.ca.gov/server/rest/services/D7Geospatial/CirgisLariacIndex2018";
      homelandSecurity = new ArcGISDynamicMapServiceLayer(urlDyn, {
        opacity: 0.7,
        visible: true
      homelandSecurity.setVisibleLayers([1,3]);
      map.addLayer(homelandSecurity);
        labelExpression: '[' +  "FILENAME" + ']',
        symbol: new TextSymbol({
                  haloSize: 2,
                  haloColor: [255,255,255]
        minScale: 30000
      optionsArray[1,3] = drawingOptions;
      map.getLayer("index_filenames").setLayerDrawingOptions(optionsArray);
      map.getLayer("index_filenames").show();
Brandon,
   Do both layers in the map service have the same field name "FILENAME"?
BrandonPrice
Yes
BrandonPrice
exact same casing also
BrandonPrice
This should work then right?
Brandon,
   No
is not valid code.
You would need
optionsArray[1] = drawingOptions;
optionsArray[3] = drawingOptions;
But I would use a whole other LayerDrawingOptions class for the other layer.
Here is another working sample labeling two different layers:
<!doctype html>
<html>
<head>
  <title></title>
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #map {
      margin: 0;
      padding: 0;
  </style>
  <script>
    var app = {};
    require([
      ], function (
      parser.parse();
        zoom: 9,
        slider: false
        opacity: 0.7,
        visible: false
      usaLayer.setVisibleLayers([1,3]);
        maxScale: 840000
      var labelClass2 = new LabelClass({
        minScale: 540000
      var drawingOptions2 = new LayerDrawingOptions();
      drawingOptions2.labelingInfo = [labelClass2];
      drawingOptions2.showLabels = true;
      optionsArray[1] = drawingOptions2;
  </script>
</head>
    </div>
  </div>
</body>
</html>
BrandonPrice
Thanks Robert. I can't get the halos to show.
var homelandSecurity = new ArcGISDynamicMapServiceLayer("https://sv07gdchfeat10.ct.dot.ca.gov/server/rest/services/D7Geospatial/CirgisLariacIndex2018/MapServ...", {
visible: true
}); //D7 Server
type: "esriTS",
color: [0,0,0],
haloColor: [0,245,255],
haloSize: 2,
"font": {
"family": "Arial",
"weight": "bold",
"size": "14px"
minScale: 35000
"type": "esriTS",
"color": [0,0,0],
"haloColor": [0,245,255],
"haloSize": 2,
"font": {
"family": "Arial",
"weight": "bold",
"size": "14px"
minScale: 35000
optionsArray[3] = drawingOptions2;
Brandon,
   Replace your:
    "type": "esriTS",
    "color": [0,0,0],
    "haloSize": 2,
    "font": {
      "family": "Arial",
      "weight": "bold",
      "size": "14px"
  minScale: 35000
with:
        symbol: {
          "type": "esriTS",
          "color": [0,0,0],
          "haloSize": 2,
          "font": {
            "family": "Arial",
            "size": "14px",
            "weight": "bold"
        minScale: 35000
