RAM for SQL Server hosting Enterprise Geodatabases
6722
19
05-27-2018 07:33 PM
ClintonBallandis1
We are currently having  memory pressure issues with the SQL server box that hosts our enterprise geodatabases.
The specs for the SQL Server Box are as follows:
Intel Xeon  CPU E5-2660 v3 @ 2.60 GHz 2.59GHz (2 processors)
Installed memory (RAM): 16 GB
Running SQL 2014 SP1 and Windows Server 2012 R2
We have about 50 spatial databases with a total size of 200GB
We are getting the following errors in ArcMap:
Error exporting data.
Table schema changes after cursor declared [4200:[Microsoft][SQL Server Native Client 11][SQL Server]
Could not complete cursor operation because the schema changed after the cursor was declared.]
AppDomain unload. You may have encountered behavior described in Esri Technical Article 43036 and Microsoft Defect 3374271 [42000:[Microsoft][SQL Server Native Client 11.0][SQL Server]The app domain with specified version id (5870) was unloaded due to memory pressure and could not be found.]
Below is a extract from the SQL Logs:
From a quick google search it appears that we may need an increase in RAM ?
Can anyone let me know the amount of RAM that they are have installed on their SQL boxes. I'm trying to justify
a RAM upgrade to at least 32gb ?
If anyone else has encountered this issue and has another fix other than increasing the RAM please let me know.
Clinton
George_Thompson
Esri Frequent Contributor
What is the current level of RAM/CPU usage when these errors occur?
Are there any other programs running on this machine that SQL Server is on?
Is this a VM?
--- George T.
ClintonBallandis1
Hi George,
We have FME desktop running on the same box. FME is used to do table joins on a nightly basis.
Yes it the server box is a VM.
George_Thompson
I do not think that FME on the same machine would cause the issue unless it was doing a resource intensive job at the time.
I have seen in the past where having the SQL machine on a VM causes issues, mainly due to over allocated host machines. When the SQL machine really needs resources they may not be available on the host and that can cause issues.
I think increasing the available memory up and then tuning of the SQL database server should help.
Update: Here are some links to UC presentations on SQL Server that may be of use, start with the 2015 presentation
UC 2015: Troubleshooting SQL Server Enterprise Geodatabase performance Issues - http://proceedings.esri.com/library/userconf/proc15/tech-workshops/tw_988-194.pdf  ans zip file: http://proceedings.esri.com/library/userconf/proc15/tech-workshops/tw_988-193.zip
UC 2017:
Troubleshooting SQL Server Enterprise Geodatabase Performance Issues: http://proceedings.esri.com/library/userconf/proc17/tech-workshops/tw_460-208.pdf
Administering Your Microsoft SQL Server Geodatabase: http://proceedings.esri.com/library/userconf/proc17/tech-workshops/tw_210-184.pdf
--- George T.
RexRobichaux2
Occasional Contributor II
Additionally, has the maximum server memory setting been adjusted to the instance properties on the server? By default, SQL will grow and use as much as it is allocated. That's a good amount of data, and depending on the volume of requests this server is receiving and serving- I could see how 16GB would possibly become limiting. In the screenshot example below, SQL has been capped at 4GB.
If you suspect that there may be specific databases that are taking up too much resources / memory or buffer pool consumption, you can identify the most intensive databases on the instance by running the following query:
The first step would be to run the following query against the SQL Instance to see a list of databases, and the respective buffer pool (% of total) contribution:
DECLARE @total_buffer INT;
SELECT @total_buffer = cntr_value
FROM sys.dm_os_performance_counters
WHERE RTRIM([object_name]) LIKE '%Buffer Manager'
AND counter_name = 'Database Pages';
;WITH src AS
SELECT
database_id, db_buffer_pages = COUNT_BIG(*)
FROM sys.dm_os_buffer_descriptors
--WHERE database_id BETWEEN 5 AND 32766
GROUP BY database_id
SELECT
[db_name] = CASE [database_id] WHEN 32767
THEN 'Resource DB'
ELSE DB_NAME([database_id]) END,
db_buffer_pages,
db_buffer_MB = db_buffer_pages / 128,
db_buffer_percent = CONVERT(DECIMAL(6,3),
db_buffer_pages * 100.0 / @total_buffer)
FROM src
ORDER BY db_buffer_MB DESC;
Once a particular database has been identified, the following SQL Query can be ran on that database to return a list of all indexes within the database, and their respective size / % contribution to the buffer pool (just update the <databasename> value from the high contributing database(s) from the first query above:
USE <databasename>;
;WITH src AS
SELECT
[Object] = o.name,
[Type] = o.type_desc,
[Index] = COALESCE(i.name, ''),
[Index_Type] = i.type_desc,
p.[object_id],
p.index_id,
au.allocation_unit_id
FROM
sys.partitions AS p
INNER JOIN
sys.allocation_units AS au
ON p.hobt_id = au.container_id
INNER JOIN
sys.objects AS o
ON p.[object_id] = o.[object_id]
INNER JOIN
sys.indexes AS i
ON o.[object_id] = i.[object_id]
AND p.index_id = i.index_id
WHERE
au.[type] IN (1,2,3)
AND o.is_ms_shipped = 0
SELECT
src.[Object],
src.[Type],
src.[Index],
src.Index_Type,
buffer_pages = COUNT_BIG(b.page_id),
buffer_mb = COUNT_BIG(b.page_id) / 128
FROM
src
INNER JOIN
sys.dm_os_buffer_descriptors AS b
ON src.allocation_unit_id = b.allocation_unit_id
WHERE
b.database_id = DB_ID()
GROUP BY
src.[Object],
src.[Type],
src.[Index],
src.Index_Type
ORDER BY
buffer_pages DESC;
 I hope this helps in determining the cause of the memory issues and confirms if you either need additional resources or if current data or settings in the instance can be adjusted to suit needs.
-Rex
BillFox
MVP Frequent Contributor
From the Rex instance slide make sure to subtract at least 4 GB RAM from the SQL server instances so the operating system always has something to work with.
ClintonBallandis1
Hi Rex,
Thanks for the reply.
The Server Memory Settings have been adjusted to the following:
Total Server Memory = 16GB
Memory Reservered for SQL = 10GB
Memory Reservered for OS = 6GB
Our infrastructure team have reluctantly agreed to add another 8GB of RAM to the box. However they aren't convinced that the memory pressure issues are related to the amount of RAM but may actually be bad SQL queries?
Once this additional RAM has been installed we plan to allocate 16GB for SQL Server and 8GB for the Operating System (Assuming that this is recommended)
We ran the SQL queries you provided and identified the following databases.
db_name
db_buffer_pages
db_buffer_MB
db_buffer_percent
Topography
321068
2508
57.508
GIS
53519
418
9.586
tempdb
46754
365
8.374
Cadastral
37069
289
6.64
WebEditor
19120
149
3.425
Object
Type
Index
Index_Type
buffer_pages
buffer_mb
CONTOURSURBAN2016OPENDATA
USER_TABLE
R28_pk
CLUSTERED
54364
424
CONTOURURBAN2016
USER_TABLE
R27_pk
CLUSTERED
48414
378
TOPOCOMBINED
USER_TABLE
R25_pk
CLUSTERED
9831
76
CONTOURURBAN2013
USER_TABLE
R23_pk
CLUSTERED
8093
63
CONTOURURBAN2010
USER_TABLE
R22_pk
CLUSTERED
4961
38
These contour datasets are very detailed and have high vertex counts.
Note: As mentioned to George above we also have FME Desktop (and an ArcGIS Desktop installation that we dont use) on the same VM Box.
Clinton
RichardBunten1
New Contributor III
Rex,
I have a similar situation to what George described with his SQL database.  I ran the queries that you provided above and determined the database that is using the most memory and the feature classes of that database that are using the most memory, but once I gather this information how can I determine if I need more RAM on the server?
I can restart the Server to reduce SQLs RAM usage, but it becomes pegged to 10GB within 2-3 days.
Any assistance would be greatly appreciated.
Server Specs
SQL 2014 SP1
16 GB of RAM
10 GB of RAM allocted to SQL
Richard
George_Thompson
I would expect the RAM to get pegged at 10GB if that is the limit set for SQL Server. Given that the FC using the most memory looks related to 1 foot contours, that are probably very detailed (i.e. lots of vertexes), that does not surprise me. I would say that you may need more memory on the SQL Server machine based on the DB's listed above. If the data is complex and being accessed frequently, then more memory may be needed.
Here are some MS Docs to review, that may help: https://docs.microsoft.com/en-us/sql/database-engine/configure-windows/server-memory-server-configur...
https://docs.microsoft.com/en-us/sql/relational-databases/memory-management-architecture-guide?view=...
the other option is to have IT increase the memory to 32GB and increase the SQL allocation to 24GB and monitor performance more than memory usage.
Is there any performance issue being experienced by the end users?
--- George T.
RichardBunten1
New Contributor III
Yes.  Users are sometimes having issues with editing.  Edit cursor will not snap or snaps very slowly, redraws and labelling can sometimes be painfully slow.  The 'Prod' SQL Instance (which I am referencing here) has a set max of 10GB.  Another 'Dev' Instance on the same server has a max of 2GB and that leaves the OS with 4 GB.
I will ask our Server Admin to add an additional 16GB of RAM to up the machine to 32GB of RAM.  I will then set the 'Prod' instance to max at 20-24 GB and see how that works.
Thanks for your help.
Richard
