Survey 123 Camera Issue - Leica Zeno 20
391
05-24-2018 06:16 AM
MatthewCriel
New Contributor III
Hello
I have run into some issues with the camera integration in Survey123.
Survey 123 is running on our new Leica Zeno 20 GPS unit.
The camera has not been functioning properly in versions above 2.6.9
When answering a photo question, it wont allow the user to see what the camera is pointing at (the screen is black or flashing black/white). But the capture button is present and works to take the photo.
Feel free to reply here if you have solutions to the problem I listed above.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Matthew,
I can reproduce the behavior you are describing.  I've filed an issue to look into this and correct the behavior.
