Calculating roadway distance within 1.5 miles of a single point
664
5
05-24-2018 07:29 AM
ShelbyPW1
I am trying to calculate 1.5 miles of roadway distance from a single point (Fire Department). Can this be done using a standard license? If so, how? If not, can this be done in QGIS and how? Thanks for your input.
Brett
JoeBorgione
That sort of question is typically answered with  ArcGIS Network Analyst | Overview .
ChrisDonohue__GISP
Can you elaborate on your question?
For example:
Chris Donohue, GISP
ShelbyPW1
For insurance purposes, I am looking to create a layer showing all roadway features that 1.5 miles traveled from the Fire Station. Thanks.
Brett
JoeBorgione
Then you need to take a look at what both Chris and I suggested with respect to Network Analyst.....
ChrisDonohue__GISP
If you have access to it, Network Analyst is the way to go.  Of course, that can easier be said than be done, as its a less-commonly used Extension, and if it is not available in your organization one will have to weigh buying it.  Also, using it can be interesting, as there is a learning curve to it and the data preparation can get pretty intense.  But if you have it and a network dataset already set up, it is an easy process to run a Service Area and then extract the roads that can be traversed for 1.5 miles from your fire station point.
Another option if you see that the cost and/or work in doing the data prep is too prohibitive is to consider hiring a consultant to do it for you.  (Both Joe Borgione  and I used to do this when we were in the Private Sector).
Chris Donohue, GISP
