Finish button grayed out.
1105
05-24-2018 10:31 AM
ralphholmes
New Contributor III
when importing open source data from get map data the finish button is grayed out
how do I finish importing data when I cannot click finish?
Luiz_AmadeuCoutinho
Occasional Contributor III
Are you using CE 2017.1? Or which one?
Did you see the Upgrade Patch?
The CityEngine Team has just issued a patch to fully restore the Open Street Map functionality:
CityEngine Get Map Data for Open Street Map Patch Released
ralphholmes
New Contributor III
Esri CityEngine 2018.0.3929 (Build Date: 180503, release, win32-64bit)
experiencing a similar issue when trying to import my own network shape-file. Going through the import tool that lets me use simplify streets the finish button is grayed out but if i just drag and drop the .shp into the 3d view it loads up fine
Luiz_AmadeuCoutinho
Check here a similar problem - https://community.esri.com/thread/189486-get-map-data-ok-box-greyed-out
Are you using a local coordinate system or another one?
ThomasFuchs
When the finish button is deactivated usually ther is a wrong or missing input. Is there any error or hint shown on the first page the greyed out finish button appears? The hint is usually shown below the tiltle of the dialog.
