Clip not working
29075
28
05-21-2018 04:51 PM
FaithWebster
I have a peculiar problem. The clip tool is simply not running. My results say that the tool ran, but the output isn't created, and there are no messages.
I have moved all the data into the same geodatabase, and it's all in the same projection. I welcome any suggestions to what could be going on because I am at a loss.
Thank you GeoNet Community!
Tags (1)
DanPatterson_Retired
All featureclasses, all in the same coordinate system for sure (?!)
Try a select by attribute and see if that works.
Make sure that you don't have any selections if you are expecting a complete clip.
And the clipping geometry is a polygon which can be used to clip, polylines, polygons or points
FaithWebster
I double checked, and yes all of the data is in the same projection, and the input and clip features are in the same file geodatabase. I can try a select by location... but i'm not sure a select by attribute would do much. I am clipping line features using a polygon. I honestly have no idea what the issue is.
Thank you for your help.
FaithWebster
So I tried just selecting by location, and then I was going to make a layer from selected features, but  I got another weird result:
I think I might have a problem with ArcGIS...
VinceAngelo
Esri Esteemed Contributor
Uninstall/reinstall couldn't hurt, but I expect the problem is with the data, not the software.
- V
Faith... did you run a Check Geometry on the data as Vince suggested?
You might actually want to make a copy to a local simple folder in a test geodatabase there first.
FaithWebster
The check geometry has the same problem as clip. it is showing in results as ran, but without messages, and no output in the database.
FaithWebster
I ran a repair on ArcGIS, and the clip ran as expected.  Thank you guys for your help, as always.
Chiu-Wen__JoAnne_Ray
How to run a repair on ArcGIS?
FaithWebster
see Dan Patterson's comment above. You right click on ArcGIS from the programs list in the control panel.
