an error occured while trying to fetch sprite data. Ideas?
1820
10
05-18-2018 11:51 AM
ClayDonaldsonSWCA
Occasional Contributor II
Running into an error when selecting a basemap.
An error occured while trying to fetch sprite data for item 7549fb39378a485ca0c9d18a2d968c15
Clay
PatrickArlt1
I have a few more questions then:
1. Does this occur on every browser on your machine? For example Firefox, Edge or Safari?
2. Does this occur for every basemap or just a few? If so which?
3. Can you update your version of Chrome? Chrome 57 is about a year old so that might be a reason for this.
PatrickArlt1
Hi Clay a few questions:
* Does this occur every time you select a basemap?
* Does this occur if you refresh the page after the basemap load?
* Could you post the info from https://supportdetails.com/  in this issue or email them to me?
It also also possible this might be related to some of the issues with sprites reported in Seem to be not working with our own vector tile package/layer? So I'll post again when we make progress on that issue
ClayDonaldsonSWCA
I was not able to get any of the basemaps to work.Refresh did not fix. Chrome was reporting this error The basemaps were not previewing either:
main.270a8eb….bundle.js:1 ERROR DOMException: Failed to execute 'getImageData' on 'CanvasRenderingContext2D': The canvas has been tainted by cross-origin data.
Operating System
Windows 10 (64-bit)
Screen Resolution
1920 x 1080
Web Browser
Chrome 57.0.2987.11
Web Browser Size
1855 x 990
Color Depth
24 bit
Javascript
Enabled
Macromedia Flash Version
29.0.-1
Cookies
Enabled
PatrickArlt1
Clay Donaldson‌ Could you try to load your basemap again? We made some fixes last week that might have resolved this issue.
ClayDonaldsonSWCA
Unfortunately, I am still receiving the same error.
PatrickArlt1
Clay Donaldson‌ An option would be to create a group and invite me (username: "patrickarlt7104") so I can take a look if you cannot make the item public. That way I can load it up in the editor and take a look.
ClayDonaldsonSWCA
Patrick, the problem occurs with the default basemaps, not a custom one.
PatrickArlt1
ClayDonaldsonSWCA
I can confirm switch browsers to Firefox fixed this problem. I am unsure if updating Chrome would achieve the same effect (lacking IT privileges).
MichaelVolz
Esteemed Contributor
Clay:
Are you trying to add a default basemap into ArcMap or Pro?  Which version?
