If/Else do nothing
4531
05-17-2018 02:01 PM
City_of_Greenville__SCGIS
New Contributor III
I'm trying to write a simple if/else statement where if the value isn't found, Arcmap keeps the current field value.  I've tried using the default python command of pass but it still overwrites the values to null.  Any advice?  Code from codeblock below.
def reclass(mystring):
      if (mystring == 'C-4'):
           return 'Central Business District'
      else:
           pass
Scott
JoshuaBixby
MVP Esteemed Contributor
The better way is to pass both fields to the function:
def reclass(f1, f2):
      if (f1 == 'C-4'):
      else:
           return f2
and call it using:
reclass(!field1!, !field2!)
JoshuaBixby
In Python, the default for a function is to return None, which will get converted to NULL in your case.  Try:
      else:
           return mystring
New Contributor III
I'm actually running it against a different field though so I don't want it to just return mystring, I should've stated that.
Here's what I want:
The field being calculated is field2
reclass(!field1!)
def
reclass(mystring):
      else:
           return the existing value in field2 or just do nothing to field2
Does that make sense?  Can I just define field2 in the codeblock and say if else return the value for field2?
Scott
JoshuaBixby
      if (f1 == 'C-4'):
      else:
           return f2
and call it using:
New Contributor III
Perfect, this is what I was looking for.
Scott
