Repeat broken in Survey123 on mobile
399
05-17-2018 06:54 AM
by Anonymous User
Not applicable
When using the survey123 mobile app the select one doesn't have any values after creating the first record. this only seems to affect the mobile app and the web version works without issue.
Have I set this up correctly?
survey type
JohnathanHasthorpe
Hi Joel
Can you attach your survey xls so I can take a look?
But using reserved words (start and end) as question names is likely to be one of the problems. Also you don't need give the end of repeats names or labels - only end repeat is required.
John
by Anonymous User
Not applicable
It's interesting that you say that because I had to put them in because when I remove the repeat name and label I get the following:
Please find attached my spreadsheet.
JohnathanHasthorpe
Hi Joel
Please see the attached. That start of a repeat does need a name and label, the end does not.
Also, make sure you don't use reserved words like start or end as a question name.
John
