Is it possible to write a python code for convert shape file to kml? Please give me the advice and way to do.Thank you
7065
20
05-15-2018 08:17 PM
kanchanarajapaksha
DanPatterson_Retired
There are existing tools in arcmap and ArcGIS Pro
KML conversion tools, Layer to KML
Sample code exists on geonet
https://community.esri.com/thread/167881
kanchanarajapaksha
Dear Sir,
Actually, I want to run a python program independently. But it says a error
'No module named arcgisscripting'
Let me know to fix it.
Regards,
Kanchana
You have to have a version of ArcMap installed on the computer you are running it on.
Dr Google has some examples of code snippets that require QGIS if you don't have an Arc* product installed
kanchanarajapaksha
Hello, Thanks for the details. Can we write python code without using the
arcpy library for shapefile to kml conversion?
never seen a pure python library, since you need at least a library to deal with the shapefile part
kanchanarajapaksha
Hello,Can we make a library of arcgisscripting using python code?
you need arcmap or ArcGIS pro or some other gis open alternative
That is it
ZackaryKing
Hi Kanchana,
If you don't have a version of ArcGIS installed on your computer you won't be able to access the arcpy module with python.
An other really easy way to convert spatial formats with python is to use GDAL/OGR.
This link will walk you through how to write to kml:
Geometry — Python GDAL/OGR Cookbook 1.0 documentation
kanchanarajapaksha
Thanks for your advice.By the way, how can I get the arcgisscripting
library for my project.Because when I run the standalone query,it says this
library is missing.But it is in the ARCGis installation folder.Without the
ARCGis installation,I cannot run the standalone program
