Difference between AGSCodedValueDomain and AGSInheritedDomain
532
05-14-2018 03:06 AM
MuruganandhamKuppan1
New Contributor III
In my previous version, i have fetched the coded values from the domains property of 'AGSFeatureType'. In latest iOS Runtime SDK, the new subclass of AGSDomain, 'AGSInheritedDomain' has been added and no domains value founded.
#2. What is the difference between  `AGSCodedValueDomain ` and AGSInheritedDomain
#3 Is there any way to get domain value form AGSInheritedDomain or to change the type from 'AGSInheritedDomain' to 'AGSCodedValueDomain'.
Nicholas-Furness
Hi Muruganandham Kuppan,
I need to find out more about the difference between the two, but this thread might be helpful to you.
Cheers,
Nick
New Contributor III
Hi Nick,
Is there any way to avoid the "AGSInheritedCodedDomain" while creating subtypes.
Regards,
Nicholas-Furness
Hi Muruganandham,
If you're reading a subtype domain from an AGSFeatureType.domains and it's AGSInheritedDomain, you should look up the table's field (from which the domain will be inherited) with AGSArcGISFeatureTable.fieldForName() and read its domain property.
Note: The key to the AGSFeatureType.domains dictionary is the field name, so you can just pass that to AGSArcGISFeatureTable.fieldForName().
For example:
for featureType in table.featureTypes {
    guard let domains = featureType.domains else { continue }
    for (name,var domain) in domains {
        if domain is AGSInheritedDomain, let baseDomain = table.field(forName: name)?.domain {
            print("** \(name): Inherited Domain!")
            domain = baseDomain
        // Now you've got the actual AGSCodedValueDomain or AGSRangeDomain…
Sorry for the delayed response on this! Hope that helps.
Nick.
