I have portal 5.1, i am trying to configure a survey allready published but i dont know how to acces survey123.arcgis.com with my portal credencials.
382
05-11-2018 09:02 AM
SebastiánArdila
New Contributor III
Any ideas?
JohnathanHasthorpe
To sign into your portal in the Survey123 website, navigate to the following URL into your browser, with the provided example portal replaced with your own portal's URL.
https://survey123.arcgis.com/?portalUrl=https://exampleportal.esri.com/arcgis
The website should open in development mode, with a message in the top bar listing your portal URL. Sign into the website with your portal credentials, and the website will now display existing surveys from the portal, and allow you to create new ones.
Note that some functionality like publishing surveys from the website and custom printing require that the portal is publicly accessible.
John
SebastiánArdila
New Contributor III
Hello Jonathan,
Thank you for your answer.
I've done what you suggested using the example URL replaced with my portal's URL and the survey123 webpage loads normally, but when i tryed to sign in whith my portal credentials i got the error shown in the screenshot below.
Any idea on why this is happening?
Thanks.
Screenshot, Error
JohnathanHasthorpe
You will need to register survey123.arcgis.com with your portal. Please see: How To: Configure Portal for ArcGIS to work with survey123.arcgis.com
John
