How to Set Transparency on ClassBreaksRenderer Levels Using Jquery UI Slider
643
5
05-10-2018 09:11 AM
BehrouzHosseini
I am trying to apply opacity to  Breaks of ClassBreaksRenderer based on jQuery UI Slider and I used the
transRange1.setOpacity(1)
for setting this but I am getting this error
sandbox.html:57 Uncaught TypeError: transRange1.setOpacity is not a function
Can you please let me know how to fix this?
require([
    "esri/map",
    "esri/layers/FeatureLayer",
    "esri/renderers/ClassBreaksRenderer",
    "esri/symbols/SimpleMarkerSymbol",
    "esri/symbols/SimpleLineSymbol",
    "esri/symbols/SimpleFillSymbol",
    "esri/Color",
     "esri/renderers/TemporalRenderer",
    "dojo/domReady!"
  function(
    Map,
     FeatureLayer,
     ClassBreaksRenderer,
     SimpleMarkerSymbol,
     SimpleLineSymbol,
     SimpleFillSymbol,
     Color,
     TemporalRenderer
    var map = new Map("map", {
      basemap: "topo",
      center: [-82.44109, 35.6122],
      zoom: 17
    var featureLayer = new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Landscape_Trees/FeatureServer/0",{
            mode: FeatureLayer.MODE_SNAPSHOT,
            outFields: [ "*" ]
    var transRange1 = 0;
    var transRange2 = 0;
     var observationRenderer = new ClassBreaksRenderer(new SimpleMarkerSymbol(), "Ht_DBH_ft");
          observationRenderer.addBreak(3, 6, new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, new SimpleLineSymbol().setStyle(SimpleLineSymbol.STYLE_SOLID).setColor(new Color([55,0,55])),new Color([55,0,55,transRange1])));
          observationRenderer.addBreak(0, 3, new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, new SimpleLineSymbol().setStyle(SimpleLineSymbol.STYLE_SOLID).setColor(new Color([65,105,225])),new Color([65,105,225,transRange2])));
         var renderer = new TemporalRenderer(observationRenderer, null, null, null);
          featureLayer.setRenderer(renderer);
    $( "#slider-range" ).slider({
      min: 1,
      max: 6,
      step: .0001,
      value: 3 ,
      slide: function( event, ui ) {
      $( "#range" ).val(  ui.value );
       if(ui.value > 1 && ui.value < 3 ){
         transRange1 = 1;
         transRange2 =0;
      if(ui.value > 4 && ui.value < 6 ){
         transRange2 = 1
         transRange1 =0;
    $( "#range" ).val(  $( "#slider-range" ).slider( "value" ) );
    map.addLayer(featureLayer);
KenBuja
MVP Esteemed Contributor
You're attempting to set the opacity of a number variable (transRange1) instead of featureLayer.
BehrouzHosseini
Thanks for reply Ken, but by setting
featureLayer.setOpacity(1);
will apply the opacity to entire featyrelayer which I do not mean to. What I want to do is filtering display of features based on addBreak  values and slider move
KenBuja
Thanks for the clarification...I didn't scroll far enough right on your code. You should be able to change the colors in the renderer with the new opacity levels using the visualVariables property and the setVisualVariables method.
BehrouzHosseini
I tried to set  all points transparent on load by using
setVisualVariables
    renderer.setVisualVariables([{
    type: "opacityInfo",
    field: "Ht_DBH_ft",
"stops": [{
               "value": 1,
               "opacity": 0
               "value": 2,
               "opacity": 0
               "value": 3,
               "opacity": 0
               "value": 4,
               "opacity": 0
               "value": 5,
               "opacity": 0
               "value": 6,
               "opacity": 0
but I am still seeing all the points on the Map!
KenBuja
Yes, I'm having difficulty working with the setVisualVariables using this sample, where it's not working as expected
var renderer = new ClassBreaksRenderer(symbol, "POP07_SQMI");
renderer.addBreak(0, 25, new SimpleFillSymbol().setColor(new Color([56, 168, 0, 0.5])));
renderer.addBreak(25, 75, new SimpleFillSymbol().setColor(new Color([139, 209, 0, 0.5])));
renderer.addBreak(75, 175, new SimpleFillSymbol().setColor(new Color([255, 255, 0, 0.5])));
renderer.addBreak(175, 400, new SimpleFillSymbol().setColor(new Color([255, 128, 0, 0.5])));
renderer.addBreak(400, Infinity, new SimpleFillSymbol().setColor(new Color([255, 0, 0, 0.5])));
  "type": "opacityInfo",
  "field": "POP07_SQMI",
  "stops": [{
    "value": 25,
    "opacity ": 1
    "value": 75,
    "opacity ": .25
    "value": 175,
    "opacity ": 0
This is the output I get regardless of how I change the opacity for each stop.
