How to "autocheck" a field?
300
05-10-2018 10:51 AM
Marcos_AntonioLima_Rios
Greetings my friends.
   Is there a way to autocheck a field with only one choice?
For exemple, we need the field "Variedade" atomatic check "CTC4".
JamesTedrick
Esri Esteemed Contributor
Hi Marcos,
You can set a default value for the question, if it needs to be checked when the form is loaded.  You can also use a calculation to set the value based on the response to a previous question.
