Remove lines in Layout view
3923
6
05-09-2018 07:33 AM
deleted-user-Jhc6Dca2JfQr
New Contributor III
Hello-
I cannot figure out how to remove these lines in layout view- see below
New Contributor III
Gentleman-
I thought I let you know what the problem was- thanks for the suggestions and hlep.
It turn out to be a added element in the map, after remover the legend, Town Logo, scale and a couple of others things the "lines" went away.
Maybe they got corrupted, who knows, however the important thing is now they are gone.
Happy mapping!!
Paul B
DanPatterson_Retired
Start toggling off stuff in the dataframe and watch to see if they vanish in layout view... also try selecting another tool in layout view, for some reason the frame is selected
New Contributor III
     Hello Dan & Thanks
I tried your suggestions but to no avail- it is some how connected to the map it self- see below-
Get whatever layer you think it is into edit mode and see if you can select it and delete it then
DanaNolan
Occasional Contributor III
Under Data Frame properties, check off any Annotation Groups. Once you figure out which annotation group this is in, in the Drawing toolbar, set your annotation target to that group. Try selecting the graphic(s) with the drawing selector/arrow. If that doesn't work, focus your data frame in Layout view using the Layout toolbar, or switch to Data view; this will let you select annotation that is geo-locked rather than page-locked. Then just use Ctl-X to cut it.
JimCousins
MVP Regular Contributor
It looks to me like these are lines on top of the dataframe in the layout view. Try selecting them using the graphics selection tool (the solid black arrow) and deleting them.
Best Regards,
Jim
New Contributor III
Gentleman-
Happy mapping!!
Paul B
