Is there a way to calculate the roundness of a polygon?
3613
05-03-2018 06:03 AM
MarlaJohnson
New Contributor III
XanderBakker
Esri Esteemed Contributor
There is an interesting discussion here: vector - Calculating roundness/compactness of polygon? - Geographic Information Systems Stack Exchan...  and some more background here: Roundness (object) - Wikipedia .
Is that what you are looking for?
DanPatterson_Retired
'circularity'  various definitions: aka roundness
You can calculate some of the volume properties using
Bounding Containers ArcMap has an equivalent toolset  (ie convex hull, MABE, aligned rectangle, minimum area circle)
Minimum Area Bounding Ellipse
Concave Hull  The ratio of the convex hull to the concave hull is often a measure of container tortuosity.
XanderBakker
An example of what you get when  you execute this field calculation using the Python parser:
4 * math.pi * !SHAPE_Area!  / !SHAPE_Length!**2
