ArcGIS 10.5.1 crashes when calling up any Geoprocessing tool, any tool from the toolbox and when loading basemap...
1164
04-30-2018 11:26 PM
Elijah
Occasional Contributor II
I run ArcGIS 10.5.1. Recently, the software started behaving starngely namely:
Each time I call up any Geo processing tool such as Buffer etc, Arcmap crashes. It does same when I call up any tool from the extension toolbox such as Project, Clip raster, etc. Attempt to load basemap crashes the software also. What actually could be happening??
I have taken these steps as seen online:
1. Cleared cache several times
2. Turned off "Hardware Acceleration"
The problem still persists.
My desktop is 32GG RAM and 4T HDD machine. So I don't think memory and space are the issues here.
Please suggest any solution.
Tags (1)
DanPatterson_Retired
Did you try the 'repair' option through Windows control panel, Add/Remove programs or should that fail.... resetting your application profile
