USGS standard symbology
1918
04-26-2018 03:59 PM
TychoGranville
Occasional Contributor II
Just now starting to play around with ArcGIS Pro. This is probably pretty obvious, but I can't figure it out ... where are the styles that have the standardized USGS symbology for polygons? I need to use those to stay consistent with things like PLSS lines and city boundaries.
Tycho
KoryKramer
Esri Community Moderator
What is the name of the style you're asking about?  Is it automatically installed with ArcMap?  If so, you could just import it to your Pro project: Add styles to a project—ArcGIS Pro | ArcGIS Desktop
ThomasColson
MVP Frequent Contributor
I believe the OP is referring to:
However, there's Pro: Importing Styles should be permanent .
