Display problems using online survey
270
04-27-2018 11:36 AM
KristenHoffman
Has anyone had any display problems with their surveys online?  I have a field that is relevant to another field, and when it appears, it appears next to the previous field and is missing it's label.  I'm not sure if there is a setting I can use to move it to the next line?  It appears fine on the app on a tablet, but when I access it through an online link, this happens. I attached a screenshot.  The field without the label is supposed to have a "Civic Number" label above.
JamesTedrick
Esri Esteemed Contributor
Hi Kristen,
Was this authored in Survey123 Connect?  If so, can you share the XLS file?
